Old 06-16-2010, 11:53 AM
Drew's Avatar
Drew is on a distinguished road
Question Fanuc spindle drive trouble
Spindle drive gives alarm 2 going from 2000 to 3000 rpm and dosn't sound right , sounds lower in pitch when running. Drive is A06b-6044-H007 and motor is A06b-1003-B100. Doesn't blow any fuses. From search this is feedback related alarm. Need help diagnosing pulse coder or PCB.
Update now alarming at lower rpm.
Thanks Drew
Pictures of drive and motor in this post
http://cnczone.com/forums/showpost.p...62&postcount=1
If I had something important to say it would be here.
Old 06-19-2010, 04:06 AM
Don Diegoo
F.Sharifi is on a distinguished road
Dear Drew
Alarm 2 that means speed is deviated from command value !
please check following point
1- firstly be sure that you dont have any mechanical over load on spindle in any how from no load or full load , with tools or without tools
2- it happen same in M03 and M04 ? same rated RPM ?
3- mostly it comes from transistor module , check it for loose connection and bad working , you can test it easy one by one
4-check all fuse F5-F6-FA-FB mostly for good connection and loose connection it always happen when drive going so dirty , as i can see your drve need full cleaning and re check for all connection
5- finally teh speed feed back signal from motor cable and connection must be check
follow up and let me know
regards
F.Sharifi
Old 06-19-2010, 12:08 PM
fanucman is on a distinguished road
Thanks Drew
never mind that..
heres what you do..
first you said you have a scope.. you need to measure PA to 0 volts and Pb.. while running the spindle at like 100 rpms..
the wave form will be a sine wave it should be .6 volts peak to peak for both pa pb.. if its not you need to adjust the sensor in the spindle motor to 6 thousands and recheck.. also check the square waveform on ch 7 and 8 i believe (you might wanna call fanuc on that one) it should be 50% duty for both channels
If that sensor has scratches on it it will need to be replaced.. if you do any adjustment to the sensor also make sure you check the run out of the rotor with a mic..
if that all looks good you need to check the transistors inside the spindle amp.. the way you do that is by first labeling all the wire locations THIS IS EXTREMELY IMPORTANT..
check for any shorts or inconsistencies between the transistors (the large black ones)..
Old 08-18-2010, 03:28 PM
Drew's Avatar
Originally Posted by fanucman View Post
never mind that..
heres what you do..
Ok I know it has been a while but I just did this and I got 0.5v peak2peak waves had 90 deg shift didn't see another wave form coming out of plug
Of the big black ones their is TM1-4 SM1-3 and DM1. Do all of these need to be checked or just some?
Thanks Drew
FR-SE spindle drive trouble cut more Mazak, Mitsubishi, Mazatrol 65 05-25-2011 10:03 AM
Need Help!- Fanuc spindle drive trouble Drew General Metal Working Machines 0 05-26-2010 09:24 AM
Need Help!- Fanuc spindle drive trouble Drew Servo Motors and Drives 1 05-24-2010 12:56 PM
fanuc 15 m spindle trouble nabil_elbadri Fanuc 1 01-10-2008 06:36 PM
fanuc 10m spindle trouble ezjn Fanuc 2 09-04-2006 05:15 PM
