Old 06-12-2010, 06:51 PM
BrianM03 is on a distinguished road
Fanuc 11m parameter write protect
I have been searching on here on how to unlock the 8000 parameter so that I can change other parameters. One other note, the edit mode does not work either. The write protect switch is enabled, and I check the connections to it. I can background edit, but not in regular edit mode. I just got the machine a couple of weeks ago. I looked and found a switch on the main board, but that did not work. Thanks for the ideas,
Brian
Old 06-13-2010, 03:16 PM
vlado is on a distinguished road
Press EMERGENCY STOP button. Press "SETTINGS" softkey twice to get "SETTING(SETTING)" screen.
Type in "8000" then press "INP-NO".
Parameter number 8000 should appear on the screen.
Type "10000001" and press "INPUT". Alarm " SW000 PARAMETER ENABLE SWITCH ON " will appear.
Old 06-14-2010, 10:17 AM
That worked, I got the parameters changed and that fixed the other problem. Thanks a lot.
Need Help!- write protect error when enabling pwe FANUC 10T AWALTERS21 Fanuc 8 04-30-2010 05:54 AM
Fanuc OT parameter(s) erwin1958 Daewoo/Doosan 5 03-26-2009 10:36 PM
FANUC 15T Write Protect bmlw Fanuc 2 10-11-2008 02:47 PM
Need Help!- Parameter write enabling on Fanuc OiT hense Fanuc 6 06-02-2008 05:26 AM
L50 parameter write Bluesman General CNC (Mill and Lathe) Control Software (NC) 0 02-09-2006 05:49 AM
