Old 06-11-2010, 01:59 AM
bursa017 is on a distinguished road
Fanuc O-TD-controlled lathe machine at low speed and fixed speed problem.
Fanuc O-TD-controlled CNC machine tools, for example, 50 motors at low speeds does not return.After a time, making stops trying to return.In 1600 for example, in an era when returns fall 1530 and again in 1600 after 20 sec out lere fixed on himself.(Machine Goodway TB-150)Waiting for help those who already have knowledge about the problem thanks..Good work everyone..
Need Help!- Problem with cnc lathe Machine (fanuc 18t) Inad Wood Lathes / Mills 0 03-05-2010 06:55 AM
Variable vs fixed speed router? tryrook WoodWorking 3 03-31-2009 08:10 PM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Fanuc 0M Spindle Speed Problem inthezone Fanuc 6 08-01-2007 04:14 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
