| Compensation is often okay with G70, the finishing cycle, so one way to do it is have U and W values that leave on enough material in the G71/72 for a compensated finishing cut.
it wont work in some cases. i dont understand why this happens... |
You are not alone. ![]() I use a Haas lathe which is similar to Fanuc and I finished up doing the roughing for a profile using G72 with the tool radius approximated in my code. Then I wrote code for the correct profile and ran two separate finishing cuts using compensation but not using any canned cycle. Tedious but it worked.
| AFAIK, you can turn it on and off in the finish shape definition and it will be applied during the G70, but it is ignored during the G71, G72, and G73 roughing cycles. |
| Some questions about radius compensation | KKamel | Mach Software (ArtSoft software) | 9 | 09-21-2008 01:14 PM |
| Radius compensation | hpmor | Surfcam | 3 | 09-18-2008 07:55 AM |
| Radius compensation in G71 | sinha_nsit | Fanuc | 2 | 07-12-2008 07:54 AM |
| Radius compensation? | cncuser1 | Mastercam | 7 | 10-18-2007 07:54 PM |
| Radius compensation in Mach3 | kayakman | Mach Mill | 20 | 12-06-2006 10:43 AM |
