Old 06-05-2010, 08:17 AM
fanucuser1 is on a distinguished road
Fanuc 18i Parameter question
Greetings -
I am in the process of loading a series of Renishaw macro's into my Fanuc 18i-MB. Parameter Write Enable (PWE) is 1; 12010 is 2; 12011 is 8980; 12012 is 12010. I want to change the range of embedded macro's by changing the value in 12011. When I try and change it I get a "WRITE PROTECT" error. I can change 12010 as well as other parameters so the issue doesn't seem to be simple parameter editing.
Is there another level of protection or something else I have missed to change parameters 12011/12012?
Thanks - Jon
Old 06-05-2010, 10:28 AM
underthetire is on a distinguished road
This what your looking for?
3202
NE8
[Data type] Bit
NE8 Editing of subprograms with program numbers 8000 to 8999
0 : Not inhibited
1 : Inhibited
The following edit operations are disabled:
(1) Program deletion (Even when deletion of all programs is specified,
programs with program numbers 8000 to 8999 are not deleted.)
(2) Program output (Even when outputting all programs is specified,
programs with program numbers 8000 to 8999 are not output.)
(3) Program number search
(4) Program editing of registered programs
Old 06-05-2010, 10:42 AM
Sorry, I neglected to mention that I have already changed NE8 and NE9 in 3202 to 0. I found that but it didn't solve the problem of 12011 having a "WRITE PROTECT" error.
I wonder if there is another level of permissions (for instance, if you wanted to edit the tool change macro?) but that might be different yet from my problem of changing 12011.
Thanks for looking!
Old 06-06-2010, 05:46 PM
gwarble is on a distinguished road
i have also run into this, on an 18i-mb on a hardinge vmc... even with the password in 12013 (which you need to change 12010 from what i understand... after changing 12010 you can then "see" the embedded macros in program storage, right?, in green) i still cant change that range... i'll check with someone who may know and see if i can find out...
- gwarble
Old 06-06-2010, 05:55 PM
Gwarble -
That is exactly the problem I am having. I may also give Fanuc a call, and if they have anything useful I will post it as well.
Jon
Old 06-06-2010, 07:34 PM
in the meantime you may be able to save your desired program within that range to the embedded space in f-rom... have you tried that? do you have that password/the ability to edit the embedded macros?
and of course there are other workarounds if you are unable to fix this... the simplest being use 7XXX program numbers and G65 P7XXX calls... but thats an annoying workaround
my machine uses 8500-8515 for embedded macros using the custom screen (and simple macro via MCD signals) as well as 9003 for the toolchange macro... but has that entire range blocked via param 12011... luckily mine stops at 9003 so i'm able to still make custom g and m-code macros
- gwarble
Fanuc 6TB control axis screw compensation parameter question JohnF Fanuc 2 12-07-2009 04:25 PM
18T parameter question cinci5 Fanuc 8 10-15-2009 04:33 AM
Fanuc 18T program/parameter question mikeyson Parametric Programing 2 10-06-2008 12:30 PM
Parameter (I think) question. g-codeguy Hardinge Lathes 4 05-18-2008 02:06 PM
Fanuc O-M Parameter question caddyshack Fanuc 1 04-22-2008 08:00 AM
