Old 06-02-2010, 11:08 AM
Adaware is on a distinguished road
Lathe with fanuc control, need help
I need som starting help with Fanuc controll. Have used Okuma a long time ago and have forgotten what the programs looked like, g-codes and so on. It's a old Fanuc controll, the lathe is from year 2000 or so.
What i need is something i can refresh my memory with if you can help me?
Step one:
Say that i got a steel axle that is 60mm in diameter. I want to remove 10mm of the end to make it shorter. I want to use a cycle of some sort where i can use the T0202 tool as to roughcut and T0303 as finishcut.
Step two:
Next i want to turn the piece down from 60 to 40mm, 100mm invards. Roughcut and finishcut with a cycle. Same tools as step one.
Step three:
I want to use the subspindel to drill a hole 50mm deep in the center of the piece and i also want to tap (taper?) the hole with m10x1, 40mm deep . I know i can drill the hole in the normal way with rotating piece and a tool that is locked, but i remember how i did it that way so i want it the sub-spindel way
Tap is T0505
Drill is T0606
I think this is enough to start with. Maybe i will post something later asking for more.
Appreciate your help
Old 06-02-2010, 06:35 PM
leggazoid is on a distinguished road
NOT TESTED!
:1234(STEEL AXLE)
(T2 FACE OFF)
(T2 ROUGH OD)
(T3 FINISH OD)
(T3 FINISH FACE)
G50 S1500
(FACE)
N20 T202
G0 X64. Z10. M8
M3 G96 S150
G72 U2. R1.
G72 P21 Q22 U0 W.2 F.25
N21 G0 Z0
N22 G1 X-.8 F.15
(TURN)
G0 X60. Z2.
G71 U2. R1.
G71 P23 Q24 U.3 W.1 F.25
N23 G0 X37.
G1 Z0 F.2
X40. R-1.
Z-100.
X59.
N24 X60. Z-100.5
G0 G28 U0 W0 M5
M1
(FINISH FACE)
N3 T303 M3 G96 S200
G0 X64. Z2. M8
G70 P21 Q22
(FINISH TURN)
G0 X60. Z2.
G70 G42 P23 Q24
G0 G28 G40 U0 W0 M5
M30
Did not understand step 3? Did you want rotary tools? need list of M-codes for your specific machine to do that. What kind of machine is it? Brand and model?
Old 06-03-2010, 01:29 PM
By sub-spindel i mean rotary tools of course. Sorry, bad language of me there
I don't know the M codes right now because i could not find the manual. Can you just write a M code so i can change it later when i find it out?
I didn't follow you completely on the program you wrote so i will ask in a different way so can i understand it better.
Here's something from a program i wrote in the Okuma i used before;
N190 G50 S1800
N200 G00 X999 Z333
N320 G96 X300 Z5 S250 T030303 M03 M42
N330 (ROUGH OUTSIDE DNMG)
N340 M08
N350 G00 X160
N360 G85 NOU D4 U.3 W.1 F.3
N370 G00 X999 Z333 M09
N380 G96 X300 Z5 S280 T020202 M03 M42
N390 (FINISH CUT OUTSIDE DNMG)
N400 M08
N410 G00 X160
N420 G87 NOU
NOU G81
N430 G00 G42 X90
N440 G01 Z0 F.1
N450 G75 X99.96 L1 (100H7 0 TO -0.035)
N460 G01 Z-70 X99.95
N470 X134 Z-87
N480 G01 X165
N490 G40 X170
N500 G80
What do i have to do to make it work in Fanuc?
The cycle is in the end as you can see and i would like to have it there since it's easy to find when i'm changing values :P
Thanks for you help
Old 06-03-2010, 08:26 PM
okuma and fanuc are very different. maybe this will help...
http://www.haascnc.com/pdf/96-8700.pdf
Old 06-04-2010, 02:05 PM
Thank you for the link!
Very explaining
ikegai fanuc fx lathe 5t control caddyshack 5T/5M 20 11-19-2011 06:39 PM
Fanuc OT Control/Colchester 2000L Lathe okhan Fanuc 11 12-15-2010 11:18 AM
Fanuc Oi-Tb control post for lathe for Gibbs metalman21 GibbsCAM 4 12-10-2010 12:31 PM
Fanuc Oi-TC control on a Dalian lathe jeep534 Fanuc 2 12-08-2008 04:29 AM
Need Help!- Homma lathe with a Fanuc 10 control drtaz Fanuc 0 02-25-2008 03:54 PM
