hi m8
first of all is easy for us if u give us some detail about u machine:
brand,model etc and how the noise apeear.---suddenly?
or u lost some parameters or u modified them?
more details more easy to help u
GOOD LUCK!
Hello I need some help my encoder on the x axes makes a humming nose when it is being moved left or in the + position and when it is just sitting in idle, does not make any noise when being moved right or in the - position. any hepl?
hi m8
GOOD LUCK!
I have a victor vcenter 4 with a fanuc 10m controller, the x axes motor makes noise when you are moving it in the left position or in positive direction its does not make any noise going the other direction is there a parameter that I need to look at or is there a motor issue it has no drag on the ball screw . Please help
today I turned my machine on to try and find why the x servo is making noise and it keeps having a alarm message Sv00 X Tachogenerator Disconnect,
SV013 X Improper V_Ready Off On the servo drive board a lite is on and beside the light is has GLS. Any Ideas
Please somebody Help
Hello, my x servo is jerking when moving in counter clock wise I have changed servo motor and still does it changed cable still same problem, you can allso stop the servo with your hand, has anybody ever had this problem? I think it is the velocity drive any help???????
I can not switch because the drive is a dual axes drive
Could you switch motors?
I switched motors and cables
So? Fail persist in X axis?
yes only on x
