Old 05-27-2010, 11:52 AM
guhl's Avatar
guhl is on a distinguished road
what "@" sign means
controller 11M
periodically "@" blinks at right lower corner of the CRT
what does it mean?
Soviet ICs are the largest ICs in the world!!! )))
Old 06-01-2010, 07:29 AM
ben_heinman is on a distinguished road
Does this happen when you enable high speed function? There are parameters to change so different things can flash there. I once saw a machine that would flash ' *uckyou ' instead of ' ai nano '.
Old 06-02-2010, 09:12 AM
guhl's Avatar
we've got this machine recently
it's 1985 production year
didn't perform any machining until
I know Fanuc opened macro B option on it
Old 06-03-2010, 07:27 AM
stevo1 is on a distinguished road
Hey Guhl,
I vaguely remember this happening on one of my old 10t’s but do not recall off hand what exactly it meant. I thought maybe something with condensing programs but do not recall specifically. When I get some time I will dig up some old notes and see if I got anything written down.
Stevo
Old 06-03-2010, 08:46 AM
cnc2149 is on a distinguished road
I've also seen a flashing @ on the status line, at times. According to the 10/11/12T Operators Manual, the @ symbol on the status line of the display indicates that 'data is being written into bubble memory'. This only applies to Series 11 and 12, since the Series 10 CNC does not use bubble memory.
Old 06-03-2010, 03:39 PM
guhl's Avatar
thanks to all
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Newbie here, can anybody explain what "swing", etc. means? squale Mini Lathe 4 11-09-2007 11:59 AM
