Old 05-26-2010, 03:58 PM
motordude is on a distinguished road
Fanuc 0i-MC ethernet card
Hello all,
I have just ordered a machine with the 0i-MC controller. It comes without the ethernet option. I was wondering if a standard PC ethernet card will fit or is it a special Fanuc card? If it is a special card, what does it normally cost?
Old 05-27-2010, 12:02 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
the 0i-C has a few different options
1. FANUC PCMCIA Card (generally reserved for Fanuc use)
2. Fast Ethernet Board
3. High speed Data Server
http://www.jinpu-usa.com/PDF_Files/s...ure_gfa633.pdf
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 05-27-2010, 12:18 AM
fanucman is on a distinguished road
no you cant put anything in there..
but i should have an embedded port which is slower..
Old 05-27-2010, 04:20 AM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
The 0i-C series doesn't have embedded ethernet function on it, only the 0i-D has it.
Best option, like Mystic Monkey says is fast ethernet board.
In the Uk it is a £1400 optional board and software.
The Fanuc Support Center Team
www.fanuc-support.com
Old 05-27-2010, 02:16 PM
Thanks, guys! Very useful information!
Best regards
John
Old 05-28-2010, 12:11 PM
gwarble is on a distinguished road
does the fast ethernet board option allow the exact same program-retrieval options as the embedded ethernet option on other controls??
(not using data server of course)
ie: with embedded ethernet, you can:
[edit] mode (i/o chan 9)
<prog>
O1 <OPTR> <+> <Read> <Exec>
to retrieve file "O0001" from the FTP server
is this the same procedure with the fast ethernet board? (except maybe i/o channel)
i assume the slow way (optr, host, embedd is similar except with "board" instead of "embedd")
thanks
- gwarble
Fanuc 21i MB ethernet interface mudassser Fanuc 2 09-16-2008 12:51 PM
ETHERNET CARD - NET GEAR ISA EA201 SpeedMetal Milltronics 3 02-06-2008 03:16 PM
Fanuc ethernet embedded 21i-MB RoberChile Fanuc 8 12-31-2006 12:09 PM
Fanuc OM ethernet connection Porknar Fanuc 4 09-25-2006 09:11 AM
Ethernet Communication with Fanuc 18i-T smabhyan General CAM Discussion 3 10-22-2003 10:45 AM
