Old 05-20-2010, 02:24 PM
davesnd's Avatar
davesnd is on a distinguished road
4th axis disable/enable
Hello - I am having trouble with a Dah-Lih VMC with Fanuc 0-Mc control. I want to be able to enable and disable the 4th axis - it looks like the machine came new with a 4th axis and has never had it disconnected before. If I disconnect the 4th axis cables I get alarms - the machine doesn't have a 4th neglect toggle switch like others I've seen. Is there some simple way (using parameters perhaps?) to enable or disable the 4th axis without adding the physical neglect switch hardware?
Old 05-21-2010, 07:59 PM
BKCOM is on a distinguished road
It depen on Keep Relay, designed by Machine tool builder
Old 05-22-2010, 01:56 PM
John_B is on a distinguished road
I did this last week on my machine with the 0m-C control, it's a different brand but it may work the same. Parameter #19 bit 1 controls the 4th axis neglect function, change it to 1 and the control should ignore the 4th axis not being hooked up.
Look in your parameter manual, it should be described there. If you don't have this, send me a PM with an e-mail address and I'll get you some info.
There are a few threads on here that discuss this also.
Rgds,
John
Old 05-24-2010, 09:44 PM
gwarble is on a distinguished road
also check your "software operator panel" which the MTB may have used to add a 4th axis neglect switch (thats how my hardinge/bridgeport vmc xp3 1000's are)
- gwarble
Enable and Disable Backlash Adjustment HackMax Mach Wizards, Macros, & Addons 1 09-23-2009 07:54 PM
Need Help!- How do you disable SMI? SpeedsCustom LinuxCNC (formerly EMC2) 3 03-04-2009 03:22 PM
Newbie- Mach3 Z-axis disable when not in use Erant General CNC (Mill and Lathe) Control Software (NC) 3 05-18-2008 06:52 AM
Need Help!- Disable FAPT F3T Pxt Fanuc 1 02-27-2008 08:28 PM
Disable switches swarfmacdaddy Gecko Drives 9 10-24-2007 02:28 AM
