Old 05-12-2010, 11:21 AM
Tornadotech is on a distinguished road
Fanuc 0MC Spindle parameters
Hi, I am working on a cincinatti milacron sabre 500. The control is a Fanuc 0MC and also has Fanuc 6s spindle drive. This machine was shorted out by and idiot and it lost all of its parameters. I have been able to get the machine back to running and moving with one remaining problem.
The machine will home out and jog and run but, if I run the spindle it will run at speed for 40 seconds and then faults out and drive shows al#29 (short-time overload). I have checked and watched the current with a meter and there is never any change in load when it faults out. If I start the spindle and keep changing speeds with the override buttons it will keep running until I leave it at one speed for 40 seconds.
The spindle wont orient either. It only uses the encoder on the motor and I have checked the encoder signals and they appear good. I think that there may be a problem with the drive parameters but they get loaded by the NC when it gets powered up. The problem I am having is that I cannot find where those parameters come from in the control.
If anyone has any clues, please let me know. I am stuck. Thanks, Tom
Old 05-15-2010, 02:54 PM
zavateandu is on a distinguished road
HI
the problem is very hard to find but i had something almost the same with 1 spindle also was not orientating and also alarm.
i solved after sometime of hard work very easy
i changed 2 wires between them on motor suply(R,S,T)
i know is make no sense but it worked since than.
so try it will be no damage.
if not is something wrong with the encoder.
GOOD LUCK!
Old 05-17-2010, 12:03 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
which spindle motor do you have ?
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 05-20-2010, 12:03 AM
Don Diegoo
F.Sharifi is on a distinguished road
you need to have clockwise phase rotation for L1,L2,L3 Ac voltage supply for spindle it may be not important for axis ( depends on drive ) but if you can go ref , jog its ok , check the supply and chang 2 phase ,...dont worry always happen !
F.Sharifi
Old 05-22-2010, 03:19 AM
HI
Is not recomanded to change L1 L2 L3 if the machine is working properly cause if u have a hidraulic cooling of the spindle will not work or if the atc use a DC motor will go in the oposite direction on tool change.
try to change on ly on spindle motor 2 phases.
GOOD LUCK!
Old 05-23-2010, 09:32 PM
gbowne1 is on a distinguished road
have you tried contacting Cincinatti Milacron? I've used their Tech support on a older maching some time ago.
Tags
fanuc 0m sabre 500
Parameters Fanuc 6M Olsson Fanuc 7 12-26-2009 08:07 AM
Need Help!- TC4 Spindle Parameters emvali Bridgeport and Hardinge Mills 6 03-31-2009 12:38 AM
Need Help!- Parameters for fanuc 0T Mrmendiola Fanuc 3 10-27-2008 11:03 AM
Need help with spindle parameters on Puma 6s with Meldas Hermle UWF851 Daewoo/Doosan 3 04-12-2007 09:40 AM
Fanuc 3M Parameters nastek Fanuc 9 12-29-2006 07:35 AM
