I've got a Fanuc 6M and I am trying to get Punchsim's DNC to work with it. I am not having any luck. Before I started playing with this I was working with a dos based software/part preview program called New Dawn Systems. I've copied the basic settings out of that into the new Punchsim (which by luck happen to match the Punchsim recommended settings) and I'm getting error 85 - Fanuc's Alarm Description: When entering data in the memory by using Reader / Puncher interface, an overrun, parity or framing error was generated. The number of bits of input data or setting of baud rate or specification No. of I/O unit is in correct. I’m using the exact settings our dos based system used, and they match your recommended settings as well, so I am unsure why it is generating that error. At first, the machine I was using didn't have COM ports so I tried a USB-SERIAL convertor. I eliminated that, grabbed an older computer to test with, and still have the issue. So now I am onto trying to figure out what else it might be. Right now my settings are: 9600 baud Parity Even 7 Bits 1 Stop Bit Xon/Xoff (Tried RTS/CTS too) ISO (Other options are ASCII and EIA, tried EIA, didn't work) Wait for Xon (tried yes and no) Any other suggestions? I'd really like to get out of the super slow dos era application. It is very much tedious to use.
__________________ Amada Pega 345 K, Fanuc 6M |
| The old DOS Software has used 9600 for longer than I've been here, and that's the better part of six years. I'm pretty computer SAVVY, but I have no idea what you mean by the tape vertical parity. Is that a parameter within the Fanuc?
| Got it working. I don't know how the old DOS machine worked, it was set to a 9600 Baud Rate and a 1 stop bit setting. Checked the Fanuc parameters and they're at 1200 baud and 2 stop bits. I changed those two settings in Punchsim and booya, working great!
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 05-10-2010 at 04:06 PM. Reason: Oh" too late. |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| Need Help!- Matsuura Mc500v seq error/magazine error | mc500v | General Metal Working Machines | 10 | 01-08-2010 01:35 PM |
| Need Help!- Error 414 Z axis error detect- servo alarm | andywids | Fanuc | 0 | 07-09-2009 10:33 AM |
| Need Help!- Error 414 Z-axis error detect servo alarm | andywids | General Metal Working Machines | 1 | 07-09-2009 09:56 AM |
| OM-A ROM PARITY ERROR "NOT RAM ERROR" | offroadxx | Fanuc | 9 | 05-07-2008 08:15 PM |
