Old 05-07-2010, 12:27 AM
Mika M. is on a distinguished road
Fanuc 18iM, logical AND
Hello Everyone!
The machine in question is Doosan H100 6 with FANUC 18iM control - and here's the problem: the block marked below yells "macro format error".
IF [#19 LT 0] GOTO991
--> IF [[#19 GT 6.] AND [#19 LT 101.]] GOTO991 <---
IF [#19 GT 148.] GOTO991
The block works just fine with FANUC 6M and 32iM so why not with 18iM?
How should the block be written to make it work?
Old 05-07-2010, 01:56 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
some thing to do with the decimal places ?
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 05-07-2010, 02:29 AM
No, I don't think so. I already tried dropping the decimal points - didn't help.
Old 05-07-2010, 05:17 AM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
Hello.
What you are trying to do is not possible on an 18 (i believe). I just tried it and got the same alarm - even without decimals.
IF[#500 AND #501 EQ] GOTO1 => This is ok - example.
For what you want to do, you need two separate lines.
IF [#19 GT 6.] GOTO1
#3000=1(WHATEVER)
N1IF [#19 LT 101.] GOTO990
Never played on a 6M before.
Hope this helps.
The Fanuc Support Center Team
www.fanuc-support.com
Old 05-07-2010, 05:45 AM
The block
didn't work with Fanuc 15M either, but this did:
IF[#19 GT 6.] AND[#19 LT 101.] GOTO991
I hope the above works with 18iM too - I can't test this right now.
Thank you all for your time!
Old 05-07-2010, 07:55 AM
sinha_nsit is on a distinguished road
AND has two uses: bitwise and Boolean.
For some (illogical, in my opinion) reason, Fanuc has made its use as a Boolean function a parameter issue. While bitwise AND would always work, Boolean AND (returning TRUE or FALSE) would work only with appropriate parameter setting. For example, on 0i you have to set 6006#0 (MLG) to 1. Other control versions may have the same or a similar parameter.
In fact, this applies to OR and XOR also.
Old 05-07-2010, 10:04 AM
dcoupar's Avatar
Parameter 6006 bit 0 is MLG on the 18i also.
Old 05-11-2010, 04:03 AM
The posts about the parameter solved the problem. Thank you sinha_nsit and dcoupar!
Tags
18im, fanuc, logical and, macro
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Need Help!- Fanuc 18iM BKCOM Fanuc 0 10-19-2009 07:10 PM
Need Help!- Fanuc 18im Post for Alphacam .AMP James_jester Post Processor Files 0 04-02-2009 02:28 AM
Post Processor for fanuc 18iM for licom alphacam James_jester Cincinnati CNC 0 03-31-2009 11:14 AM
