Old 05-06-2010, 01:25 AM
MadMax is on a distinguished road
Help please: Fanuc spindle alarm AL-33
I just received a Hardinge T42 which was working when inspected, but on arrival it's giving me an alarm code: AL-33 on the LED display on the spindle servo drive. Controller is 18t and as far as I can tell it's hooked up properly to power. Hydraulics work so the phase is fine.
I looked up the error code and it's described as "SHORTAGE POWER CHARGE" which sounds like some sort of voltage isn't high enough somewhere.
Has anyone else got experience with this glitch?
Old 05-06-2010, 11:27 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Have a look at this
Name:	Fanuc Alarm 33.JPG‎
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 05-07-2010, 12:05 AM
underthetire is on a distinguished road
Look at the chart from mystic. Then inspect all cables and breakers. The electrician probably bumped something pulling wire. Happens all the time.
Old 05-08-2010, 12:41 AM
Thanks mystic. Where did you get that document? I'd love to get my hands on it in PDF if it's available online.
I just had the Fanuc tech in today. Swapped out the wiring board and it fixed the problem. First I checked voltage points between incoming mains and the board input side and found negligible voltage drops. All the screwdowns are tight, couldn't find a loose wire.
I suspect a bad relay on the wiring board now as different error message also started popping up (AL-51 I think: low volt DC link) that also *****ed about a bad relay. I decided to start pulling components for component level troubleshooting to see if I can fix the board myself. So far $25 of parts are coming in from DigiKey (relays). I have to take a stab at fixing this. The new board is $1,100 bucks with the trade in on the old board.
The failure is intermittent so I think it's something electromechanical or electrochemical like the relay or maybe a bad capacitor.
Old 05-09-2010, 06:35 PM
Don't know about a pdf but it is fanuc manual B-65165EN/02
you will just have to search google
AL-51 indicates exactly the same remedy, check the cable between the PSM and the Axis drive else you have a faulty PSM - send it for repair
Old 05-11-2010, 03:27 AM
CNCZILLA's Avatar
CNCZILLA is on a distinguished road
MysticMonkey is correct. I would highly suspect your PSM. Its awful strange that Fanuc fixed one problem and another has crept up that indicated possibly the same trouble area. Good luck
Old 05-11-2010, 07:10 PM
gbowne1 is on a distinguished road
If you need a pdf B- or GFZ-65165 I think have one.
Greg
Old 05-14-2010, 12:28 AM
It seems that I managed to fix the problem. Changed out two relays on the wiring board and the Al-33 is gone. Time to make some chips! Thanks for your help all.
Fanuc OT spindle alarm - 408 rai Fanuc 4 05-07-2010 09:13 AM
Need Help!- fanuc 0M-D spindle alarm samu Fanuc 13 11-15-2009 07:50 PM
Fanuc 10T spindle alarm hell_pk Fanuc 2 06-04-2009 01:19 AM
Fanuc spindle alarm AL-12 kadettevo Fanuc 7 05-29-2007 10:19 PM
Fanuc spindle amplifier alarm 11 Eagle View Fanuc 1 05-15-2007 05:10 AM
