Old 04-27-2010, 04:38 PM
alexium2007 is on a distinguished road
When i need used G11 ? (Fanuc 31i)
Hello everyone.
I have a question about codes G10/G11 (Fanuc 31i). I know, G10 is used to transfer data into the system via program. I want to use the code G10 for automatic adjustment of the coordinate system (G10 L2 P1 X_Y_Z_). Do I need to use the code G11? When i need used this code? I do not have info in guide, except that this option. Code G10 works on my machine.
Old 04-27-2010, 06:11 PM
ou812 is on a distinguished road
The only time I have ever used a G11 is when changing parameters or tool life management. Neither I want left open for accidental adjustments by a program or operators.
As for tool or work offsets I just command the G10 and go, never added a G11 for this.
Old 04-28-2010, 01:32 AM
sinha_nsit is on a distinguished road
Yes.
A difference from other applications of G10 is that it behaves as a modal code, when used for parameter entry. Once it enters parameter entry mode, as many parameters as desired can be entered in subsequent blocks, till this mode is cancelled by G11.
In other applications, G10 remains effective only in the block where it is commanded, like a non-modal code. In the next block, if G10 is needed again, it has to be explicitly commanded. Obviously, there is no need to program G11 in such cases.
Old 04-28-2010, 08:47 AM
Thanks for the replies. If anyone has the instructions for use the code G10/G11, please share
Old 04-28-2010, 09:47 AM
guhl's Avatar
guhl is on a distinguished road
Hi
I don't write in Russian, as it's English language forum.
I can send you russian manual for 0i series. there is info about using G10 in it
report me your email
Soviet ICs are the largest ICs in the world!!! )))
Old 04-28-2010, 09:56 AM
dcoupar's Avatar
This macro uses G10/G11 to set the X/Z 2nd Zero position. The operator moves X and Z to where he wants the G30P2 (2nd Zero) and runs the macro.
O9010 (G30 AUTO-SET)
#101=#5021*25400.
#102=#5022*25400.
G10L50 (PROGRAMMABLE PARAMETER INPUT MODE)
N1241P1R#101 (SET 1241 X TO CURRENT X MACHINE POSITION)
N1241P2R#102 (SET 1241 Z TO CURRENT Z MACHINE POSITION)
G11 (CANCE G10 MODE)
M30
Old 04-28-2010, 02:32 PM
dcoupar, Thanks for the example. Now I understand how it works G10/G11.
guhl, I sent the email to you in a personal. Thank you
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
