Hello I have a freind that bought a older Mori seiki SL-15 turning center. After hooking up power to the machine the "error" light on the front of the controller is blinking. He says there is no alarms on the CRT so he is at a loss as to what it could be. The chip convayor works and the chuck will clamp and unclamp but other than that it will not do anything. Just wondering if anyone might have some idea as to what it could be . Thanks for any help!! |
| well, you may be in for a lot of work if it did, usually barfeeds are interfaced in to the Estop circuit, chuck clamp circuit, and sometimes a lot more depending on what barfeed type was on it. Look in the back cabinet for a toggle switch that says B/F, need to make sure it's off it has one. |
| This is the friend that had the problem. The machine came on after findings some loose connections. Now I have found out the x axis ball screw is gaulded. Always nice buying used equipment. I posted some questions about it. Thanks for all the help. Farrell |
| yo some days ago i had the same no allarmbut a redl led blinking. is no alarm on crt but the machines said all the time u have not made the reference so all the time is only for not to put in automatic witout refernece point after making reference when u press RESET it dissapear if u press RESET witout making referfence will not dissapeear so was just a led with no alarm maybe help GOOD LUCK M8! |
| Ground fault error light on 1991 Partner 1D servo amps | Jim Shaper | Milltronics | 9 | 03-09-2010 06:35 PM |
| Seig X3 spindle trouble (speed error, fault light) SOLVED | iandh | Benchtop Machines | 7 | 01-21-2010 08:49 AM |
| Problem- Pro E 'blinking' problem | John@CRDM | PTC Pro/Manufacture | 3 | 03-05-2009 05:21 AM |
| Need Help!- Mazak T32 - Single Block - Blinking Light | Artur_Chicago | Mazak, Mitsubishi, Mazatrol | 4 | 09-02-2008 10:09 PM |
| Error Light on HP 7475 Help Needed | emc3zach | Printing, Scanners, Vinyl cutting and Plotters | 5 | 07-30-2006 01:15 AM |
