Old 04-27-2010, 07:26 AM
padobranac's Avatar
padobranac is on a distinguished road
197 C-AXIS COMMANDED IN SPINDLE MODE
Machine is lathe Romi G15SM
Control Fanuc 18i-TA
Alarm: 197 C-AXIS COMMANDED IN SPINDLE MODE
Here is whole program.
Machine stops and alarms at point "PROBLEM" in red color.
When machine reads this line "G0 X0", in DISTANCE TO GO there is value for X and C. Obviously it thinks it is still in circular interpolation?!
Anyway, I have to push RESET, go to line "(CENTER DRILL 8 TM)" and than run program.
There is same thing lower in the program (C-mode with circular interpolation and spindle mode after it), but there is no problem, no alarm.
I attached M-code list of machine.
O0680 (PLATE-BRNO550-FIX-1)
G90 G40 G18 G54
T0004 (LONGEST)
G0 Z20
(PULLER)
T0808
G94 F3000
G0 X30
G0 Z-20
M45
M3 S20
G4 P4000
M5
M46
G1 X0
G4 P2000
M24
G4 P2000
G91
G1 Z9.4
G90
G4 P2000
M25
G4 P2000
G1 X30
G0 Z2
T0004 (LONGEST)
G0 Z20
(TURNING)
T0101
M45
G95 F0.08
G96 S100
G92 S3500
G0 X18
M4
G0 Z0
G1 X-2
G1 Z1
M5
M46
T0004 (LONGEST)
G0 Z20
(CUT OFF 2.2)
T0202
M45
G95 F0.1
G92 S3000
G96 S50
G0 X18
M3
G0 Z-9.1
G1 X8
G1 X18 F0.5
G0 Z2
M5
M46
T0004 (LONGEST)
G0 Z20
(END MILL 12)
T0606
M45
G97 S2000
G94
G0 X50
M16
M19 (C-AXIS ON)
G28 G91 G0 C0
G0 G90 C0
G0 Z2
G12.1 (CIRCULAR INTERPOLATION ON)
G42
G1 X-10.3 C12 F5000
G1 Z-7.5
G1 C0. F200
G3 X10.3 C0. R5.15
G1 C5.55
G3 X8.9 C6.25 R0.7
G1 X-8.5
G3 X-9.9 C5.55 R0.7
G1 C0.
G3 X9.9 C0. R4.95
G1 C5.55
G3 X8.9 C6.05 R0.5
G1 X-8.9
G3 X-9.9 C5.55 R0.5
G1 C4.55
G2 X-23.9 C-4.989 R10.
G1 Z2 F5000
G40
G13.1 (CIRCULAR INTERPOLATION OFF)
M18 (C-AXIS OFF)
M17
M46
M5
T0004 (LONGEST)
G0 Z20
(CENTER DRILL 8 TM)
T1212
M45
G95 F0.04
G97 S2500
G0 X0 (PROBLEM)
G0 Z1
M3
G1 Z-3.6
G4 P500
G0 Z2
M46
M5
T0004 (LONGEST)
G0 Z20
(DRILL 4 HSS)
T1111
M45
G97 S2500
G94
G0 X0
M3
G0 Z1
G1 Z-9.2 F110
G1 Z2 F5000
M46
M5
T0004 (LONGEST)
G0 Z20
(END MILL 7)
T0404
M45
G97 S2500
G94
G0 X0
M3
G0 Z1
G1 Z-3 F50
G4 P500
G1 Z2 F1000
M46
M5
T0004 (LONGEST)
G0 Z20
(CHAMFER MILL)
T1010
M45
G97 S2000
G94
G0 X50
M16
M19
G28 G91 G0 C0
G0 G90 C0
G0 Z2
G12.1
G42
G1 X20 C6.05 F5000
G1 Z-4.5
G1 X-9.9 F200
G1 Z-3.5
G1 C0.
G3 X9.9 R4.95
G1 C12
G1 Z2 F5000
G40
G13.1
M18
M17
M46
M5
T0004 (LONGEST)
G0 Z20
(CUT OFF 2.2)
T0202
M45
G95 F0.1
G97 S2000
G0 X18
G0 Z-9.1
M3
G1 X-1
G1 Z-8
G0 Z2
M5
M46
T0004 (LONGEST)
G0 Z20
M99
Sorry for bad english
Old 04-27-2010, 10:50 AM
gabedrummin is on a distinguished road
I dont see a M43 C axis connect......
Old 04-27-2010, 12:03 PM
padobranac's Avatar
I think this is not used on my machine...
For M43 manual says "Chuck Clean Off".
I have done pretty much programing (cutting) with C-axis since now, always using same principle, and never had problem like this.
Old 04-27-2010, 01:35 PM
viorel26's Avatar
viorel26 is on a distinguished road
try to put M3 before G0 X0 (PROBLEM)
Old 04-27-2010, 05:30 PM
Ozemale6t9 is on a distinguished road
Looks ok to me. My only question would be is the line definitely G0 X0 and not C0 X0 in the machine?
Old 04-28-2010, 01:13 AM
padobranac's Avatar
Tried this before and now again, doesn't help.
It is G0 X0 for sure. In other case, when I push RESET and continue program from this tool, at line (CENTER DRILL 8 TM), it would alarm again.
But when I do that program runs OK.
Old 05-04-2010, 12:23 AM
padobranac's Avatar
Any other ideas?
I have tried to put G1 X0 F1 instead of G0 X0 but no help.
I tried to put some other value for X different than 0. No help.
In every case when machine reads this line in Distance to go there is value for X and for C. And alarm.
After pressing OK and starting program from this line again, everything is OK... until it comes to this line again (after one cycle).
Old 05-04-2010, 02:41 AM
sinha_nsit is on a distinguished road
When you get the alarm, is G13.1 active?
Old 05-04-2010, 05:45 AM
padobranac's Avatar
Very good question. I have not checked it before.
Now I see that G13.1 IS ACTIVE when I get alarm.
It means that circular interpolation is CANCELED.
So why it wants to move "X and C" when I give X...
PMC-ALARM 202 "Commanded Tool in Spindle" moldmker Mori Mills 2 04-22-2009 10:58 PM
Need Help!- Bridgeport EZTRAK Alarm: commanded X-axis move too far positive Pribbs Bridgeport and Hardinge Mills 4 01-23-2009 08:34 AM
Need Help!- Alarm: commanded X-axis move too far positive JonMatear Bridgeport and Hardinge Mills 3 08-06-2008 08:41 AM
parser: commanded z axis move to far possitive tonymann Bridgeport and Hardinge Mills 1 11-09-2007 11:05 PM
Now I get a "197 C-AXIS COMMANDED IN SPINDLE MODE" ALARM theemudracer Fanuc 14 01-07-2007 11:10 PM
