i have a program like this T1111 G97 M3 S1200 G0 XO. Z.1 G83 Z-1. Q.05 R.1 F.005 G80 G28 U0. W0. T1100 i am using a fanuc oi-TC and it comes up with a alarm that there is an illegal decimal point. all i am trying to do is drill a hole in some stock with the drill with NO live tooling can some one help |
| come on guys.... this is basic,,, don't try to guess his problem, read all the code first, if he doesn't actually say on which line his program alarmed |
| Yes, replace O with 0. Q has to be in mm or inch (your program is ok). You are not using live tooling, or it is not available on your machine? The drilling canned cycles are meant to be used with live tooling. So, if live tooling is not available, there is a possibility that these canned cycles are not enabled on your machine. This is what somebody commented in one of the threads. For drilling at the center, G74 also can be used, if G83 etc. is not available. In G74, Q has to be in steps of 0.0001 inch (or in microns in millimeter mode). |
| the program on the machine has the X.0 not X.O just a typo sorry for the confusion. The machine does have live tooling but i am just trying to drill with the drill mounted in a callit in a boring bar pot and i just need to drill a one inch deep hole in a work piece. I don't want to program a peck cycle line by line and i don't have the z axis live tooling pot in the territ so how would i do this. (would it just be ezer to just mount the z axis live tooling pot) |
#10
| I COPIED THIS OUT OF A WORKING PROGRAM THAT I RUN ON MY LATHE W/ FANUC 0i-TC HOPE THIS HELPS (TAP DRILL) (11/32" TWIST DRILL) G18G54G99 T0808 G50S3000 G97S556M3 G0X0.0Z0.1M8 G83Z-.6R0.Q7000F0.006 G80 G97S400 G0G28U0.W0.M9 M1 Q7000 IS = TO .7 / INCH PECK INCREMENT. BASICALLY THERE IS NO PECK IN THIS CYCLE BECAUSE THE PECK IS EQUAL TO THE START PLANE PLUS THE DEPTH. |
| CL2000 drill cycle | cutshaw | Mori lathes | 1 | 02-25-2009 11:48 AM |
| C Axis Drill Cycle | gtrrpa | Parametric Programing | 3 | 06-15-2008 02:12 PM |
| canned drill cycle | nitrosnfr | General Metalwork Discussion | 2 | 05-24-2006 10:50 AM |
| error in drill cycle | TPPJR | OneCNC | 2 | 01-28-2006 12:21 PM |
| G83 peck Drill cycle | Vaughan | G-Code Programing | 24 | 03-19-2004 11:11 AM |
