Hello, We have a Cincinnatti Sabre fitted with Fanuc 0M and a Feeler lather fitted with Fanuc 0T and both these machines have a problem with putting a decimal point (or even a full stop or period) in a bracketed comment. It simply doesn't happen when you are inputting a c comment while standing at the machine no matter how much stab at the decimal point key (and before you ask, we need to do this so we can call down programs from the server directly from the machine). My hope would be that this is a simple parameter setting and some kind soul is going to help me out by pointing me to the right place to make a change so I can happily input (O1234.TAP) into my DNC control program Many thanks Bob |
| The only reference I can find to decimal point input is prm0016 bit 3, and it doesn't say anything about decimal point or period within a comment. What DNC software are you using? Does it not have a "default" extension that will allow you to omit the ".tap"? |
| There must be a way of inputting a full stop (or decimal point) into a comment I'm sure. The problem is that this control is so old getting support isn't easy, hence my post. I'll check out that parameter and I;ll be mindful of what else might get broken if I change it. |
| Thanks for that Mark. I have just had a look at a Feeler lather we have with Fanuc 0T on and that doesn't even have a means of inputting comments at the control. It looks like I am going have completely restructure the program libraries for these machines if I want to use remote DNC. |
| decimal point Gcodes G90.1 G91.1 | Karl_T | CamSoft Products | 0 | 10-22-2009 02:24 PM |
| Forcing a decimal point from a pci | inflateable | EdgeCam | 0 | 10-28-2008 08:58 AM |
| Illegal use of decimal point | barbter | NCPlot G-Code editor / backplotter | 1 | 07-07-2008 06:06 PM |
| decimal point | stevieboy | Mastercam | 9 | 01-10-2007 05:42 AM |
| Decimal point placement | Zeekh | Haas Mills | 5 | 11-04-2006 07:18 PM |
