Old 04-17-2010, 03:48 PM
terminator is on a distinguished road
fanuc t6
HI I NEED ANY INFO TAKISAWA TX210D PRODUCTION
LATHE.
THE YEAR MODEL IS 1980.
THE CONTROL IS FANUC T6 AND HAS A HYDROLIC CHUCK.
CAN ANY ONE TELL ME WERE I CAN GET MANUALS ON THIS LATHE
AND IS IT POSSABLE TO CONNECT IT TO MY PC OVERRIDING THE
TAPE READER.
IS THE X AND Z AXES BALLSCREW AND SERVO MOTOR DRIVEN.
ANY INFO WILL BE GREATLY APRECIATED.
REGARDS
DANIEL
SOUTH AFRICA
Old 06-08-2010, 01:57 PM
TAKISAWA TX 210 D
HI EVERYONE.
I HAVE WORKED SOLID FOR ABOUT FOUR WEEKS NOW AND FINALLY MY
MACHINE MOVED ITS SERVO'S ON X AND Z AXES.
I ALMOST WENT TROUGH THE ROOF BUT MY JOY WAS SHORT LIVED.
I JOGED THE AXES AND PLAYED WITH THE MANUAL PULSE GENERATOR
FOR ABOUT HALF AN HOUR.
THEN I NOT HAVING A PROGRAMMING AND SETUP MANUAL CHANGED OR DELETED SOME PARAMMETERS.
THAT WAS THE LAST TIME THAT ANY AXAS MOVED AND I HAVE BEEN CRYING
EVER SINCE. NO POWER OUTPUT TO SERVO MOTORS.
THE CONTROL IS A FANUC 6T AND THE YEAR IS 1980.
MACHINE NO IS TAUNY0082.
COME ON IT IS ONLY 30 YEARS OLD SOMEBODY MUST STILL BE AROUND THAT CAN HELP ME RECOVER THE PC AND OTHER SETUP PARAMMETERS.
THE 2 VELOCITY DRIVES POWER UP AND GO TO GREEN LED VREDDY STATE.
AS SOON AS I JOG THE DRO RUNS TO ABOUT 6.000 AS SET IN MACHINE
PARAMMETER 078 AND 079 AND THEN TRIP OUT BOTH VELOCITY DRIVES.
THEN I RESET AND BOTHE DRIVES AGAIN REDDY.
PLEASE ANYONE HELP
REGARDS
DANIEL
SOUTH AFRICA
Old 06-08-2010, 02:12 PM
Al_The_Man's Avatar
Are the servo's moving when you are jogging?
If 078 & 079 are set for the equivalent of 6.00 (mm?).
And the axis do not move then this is the amount of position error.
Old 06-08-2010, 02:35 PM
TAKISAWA TX 210 D
NO SIR NO SERVO MOVEMENT.JUST ERROR 411 AND 421 AS THE DRIVES
TRIPPED OUT.
THEN I RESET AND VREDDY BOTH DRIVES.
THERE WAS MOVEMENT AND ALL WAS FINE THE ONE MOMENT AND
THEN I PUNCHED IN SOMETHING OR DELETED ANS NO MORE SERVO OUTPUT.
THERE WAS NO SIGHN OF ANY SORT OF FALURE LIKE NOISE OR SMOKE
OR EVEN LIGHTS DIMMING.
I MESSED UP THE PARAMMETERS I THINK.
THE MACHINE PARAMMETERS I WROTE DOWN 0 TO 166 BEFORE THIS HAPPEN
BUT NOT THE SET AND PC PARAMMETERS.
ANYWAY SIR I HOPE YOU CAN HELP OR KNOW WHO HAS SAME MACHINE AS
MINE THAT CAN HELP WITH PAREMMETERS AND SETUP.
REGARDS
DANIEL
Old 06-08-2010, 03:06 PM
Al_The_Man's Avatar
When you power up can you turn the servo's by hand?
If so it appears you do not have power on the servo drives, or they are disabled?
I only have the Fanuc 6T Maintenance manual, have you tried to contact Takisawa direct by email?
Old 06-08-2010, 03:27 PM
TAKISAWA TX 210 D
NO SIR NO STIFNESS ON THE BALLSCREWS WHEN I MOVE THEM BY
HAND POWER ON.
ALL THAT HAPPEN ON BOTH AXES WHEN I MOVE BALLSCREW IS AS
ENCODERS PIC UP MOVEMENT THE VELOCITY DRIVES TRIP OUT.
THE 3PHASE POWER IS ON FOR BOTH MOTORS (60V AND 90V) TROUGH THE
CONTACTORS ON TO THE TYRISTOR MODULES.
ON THE MOTOR OUTPUT SIDE NO RESPONSE ON DC MULTIMETER.
I HAVE CHECKED ALL FUSES AND INFACT HAVE NOT BLOWN ONE FUSE
SINCE I STARTED ON THE MACHINE.
IS THE PC PARAMMETERS REALY SO DEDICATED TO ONE MACHINE OR ARE THEY FLEXABLE.
I ALSO HAVE A FANUC MANUAL BUT THEY ONLY EXPLAIN THE CONTROL PAR
SET PAR AND DIAGNOS PARAM.
IS THERE INFO ON PC PARAM THAT I CAN UNDERSTAND AND TRY TO WORK
THEM OUT MY SELF.
I WILL TRY TAKISAWA KINK THANKS.
REGARDS
DANIEL
Old 06-08-2010, 03:51 PM
Al_The_Man's Avatar
What do you mean by PC parameter?
Old 06-08-2010, 04:12 PM
TAKISAWA TX 120 D
SIR IN MY MANUAL ON PAGE 112 AND 113 THEY TALK ABOUT (PC).
POWER SEQUENCE CONTROL.
MY RECEARCH INDICATE THAT THE PC PARAMMETERS ARE SET BY THE
MACHINE MANUFACTURER (TAKISAWA).
FANUC CANT HELP ME AS THIS IS DEDICATED TO THIS MACHINE NO. YEAR AND MODEL.
THEY ALL SAY I MUST FIND A MACHINE EXACTLY LIKE MINE AND RECORD
PC PARAMMETERS BY HAND AND PUT THEM IN MY MACHINE.
REGARDS
DANIEL
Old 06-08-2010, 05:41 PM
Al_The_Man's Avatar
The PC in this case is what is now called the PMC, this is the machine control program that communicates with the NC side to control external machine functions, the bits can be seen in the diagnostic list of I/O.
The next section is details of these dedicated I/O assignments, if your machine has a PC then the diagnostics are 000~063 for physical I/O and 064~118 for PMC-CNC communication.
For example 033 bit #6 is *SVFX, servo off, the '*' means it is active low.
All these can be monitored on the diagnostic screen.
Old 06-09-2010, 08:40 AM
memoryman is on a distinguished road
Can you call me on Skype? my name is tulipmemory.com
  #11   Ban this user!
Old 06-10-2010, 04:56 AM
TAKISAWA TX210D
HI SIR (AL The Man)
SORRY BUT THE OTHER NIGHT I FELL ASLEEP BEHIND THE MOUSE AND KEYBOARD.
ANYWAY IF YOU COME ACROSS ANY THING TO HELP ME I WILL BE VERY
GRATEFULL IF YOU COULD POST ME HERE.
I SOMEHOW DELETED THOSE PERAMMETERS AND I DONT EVEN KNOW THE
CORRECT PROCUDURE TO TYPE THEM IN IF I GET THEM.
I HAVE BEEN TRYING TO TYPE PAR WITH KEYLOCK ON , OFF PAR SWITCH ON , OFF EMERG SWITCH IN , OUT AND WHAT HAVE YOU.(DONT REALLY NOW WHAT I AM DOING)
IT IS VERY HARD WITH OUT THE MANUALS.
REGARDS
DANIEL
  #12   Ban this user!
Old 06-10-2010, 05:07 AM
TAKISAWA TX210D
HI SIR (Memory Man)
IF YOU COULD HELP ME IN ANY WAY I WOULD BE VERY HAPPY.
MY MACHINE TX210D BUBBLE MEM MACHINE NO TAUNY0082
1980 MODEL.
I DONT HAVE SKYPE AT HOME BUT COULD GO TO A FRIEND.
ANYWAY I THINK MY PROBLEM IS WITH PARAMETERS (NO XZ SERVO MOVEMENT).
MY EMAIL ADRESS (katsesleep@yahoo.com)
REGARDS
DANIEL
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
