Old 04-16-2010, 10:50 AM
fomaz is on a distinguished road
Auto mode only after single block
My machine with a 21-TB can only enter in "full" auto mode, if I have single block on, and when some movement occurs if I turn off the single block machine continues as it should in full auto mode. This would be ok, if I would not have to press several times the "start" so that the first line of movement code appears (I normally put large headers in the code!).
This is some paramenter? It is for safety? or is just like that in your lathes (standard)?
This is my first Fanuc lathe, and I really do not like it as it is.
Thank you
Old 04-16-2010, 05:26 PM
Ozemale6t9 is on a distinguished road
If you have several lines of header, each having an EOB, then you will need to press start for each of these lines in single block mode. A block is a block regardless of what it contains. If it is particularly a problem, you could put a slash (/) at the start of each header line, and use block skip. However this may be a problem if you are using "/" elsewhere in your program.
Old 04-17-2010, 01:52 AM
sinha_nsit is on a distinguished road
/ is used for block skip as well as division. Since mid-block skip may also be allowed, there is likely to be a confusion regarding function of /. A very simple solution is to use square brackets to enclose division operation. For example, in place of #1 = #2 / 3, use #1 = [#2 / 3]. In the second case, / would always mean division, irrespective of block-skip switch setting.
Old 04-17-2010, 02:36 AM
I probably did not explained myself very well.
I know what is single block mode.
What I expected to happen in my lathe, is that, when single block mode is not active and I am in MEM mode (auto), if I press start cycle, the cycle should start. In my machine it does not.
I need to be on single block until some movement happens, and then I need to remove single block so that the machine goes on automatically. If I do not remove the single block, of course I need to press start cycle in each block (as expected).
Since this is my first fanuc lathe, I do not know if this is the way that is done standard.
On DNC, that does not happen and machine starts right on full auto.
Old 04-17-2010, 02:56 AM
It appears to be ladder-related.
Incidently, the door should be fully closed for continuous operation in AUTO mode; otherwise it will execute in single-block mode.
Old 04-17-2010, 03:07 AM
christinandavid's Avatar
christinandavid is on a distinguished road
Our 31i will behave as 'single block' if interrupted/restarted in the middle of a program. 'Emg.Release/Reset' button must be pressed to regain 'full' auto operation.
DP
Old 04-17-2010, 03:49 AM
Doesn't the RESET key cancel the execution?
Old 04-17-2010, 04:53 AM
I will have to check the ladder then.
Thanks!
Need Help!- T MSR AUTO MODE IN MAZAK! sridhartsr Mazak, Mitsubishi, Mazatrol 2 03-28-2009 04:34 PM
Problem- Okuma LB-15 Sinble blocks in auto / single block off. mcrosby Okuma 3 03-23-2009 08:57 AM
Need Help!- title block and auto update foxsquirrel Mastercam 1 03-20-2008 08:56 AM
Auto Block Workpiece camtd PTC Pro/Manufacture 1 04-25-2006 05:55 PM
Single line mode works well, Auto is not soo good?? Darc CamSoft Products 16 10-26-2004 03:29 PM
