Results 1 to 2 of 2
Thread: Unhappy Fanuc Motor and Drive Drawing high Amperage
    Apr 2003
    Question Unhappy Fanuc Motor and Drive Drawing high Amperage
    I have a 11 series controler. My axis motor overheated and started alarming. I replaced the motor but now find that when powered up I draw 0 amps. But when I move the axis it jumps to 12 amps and continues to draw 12 amps even when stopped.
    I hace change encoders. power supply and checked that all parameters are original. Without the motor attached to the ballscrew it seens OK. I can muve the axis without the motor atatched by hand. I have backed off the gibs and such to eliminate mechanical load. Anyone have a idea as to what I might be missing?
    Jan 2007
    india
    Is it Ac motors, then u have to tune the encoders with motor.
    try adjusting the gain pot on pcb.
  1. Need Help!- Fanuc 11m Spindle drive code 11: "DC Link Voltage High"
    By cwtoyota in forum Fanuc
    Last Post: 04-09-2010, 11:56 AM
  2. What drive for Fanuc aiF12 motor?
    By Hermle UWF851 in forum Servo Motors and Drives
    Last Post: 08-30-2009, 04:43 PM
  3. High voltage & high power servo drive design
    By Xerxes in forum Granite Devices
    Last Post: 08-22-2008, 10:24 PM
  4. Looking for a Drive for a Fanuc motor
    By 69owb in forum Servo Motors and Drives
    Last Post: 03-29-2007, 07:40 PM
  5. Mini Mill Motor Amperage
    By jjwl89 in forum General Metal Working Machines
    Last Post: 06-24-2004, 07:56 PM
