Old 04-14-2010, 11:08 PM
firekoe's Avatar
firekoe is on a distinguished road
program stalls on M10
i have a yama seiki lathe with a oi control and today it will not read past a
M10 in the program. it will read the M10 and open the chuck and then it will not go any further the feed button is lite up but nothing will happen. has anyone know how to fix this problem i think that it is in the parameters but not shure
Old 04-14-2010, 11:43 PM
underthetire is on a distinguished road
Sounds to me like it's not getting the unclamp finish signal from the prox switches on the back of the chuck actuator. Some machines use a pressure switch for this instead of prox switches. Don't know yama seiki
Old 04-15-2010, 09:23 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
You haven't put two "M" codes on the one line-my machine (different to yours) won't let me have more than 1 "M" code on a line. Just in case.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 04-15-2010, 09:43 AM
firekoe's Avatar
thanks to "underthetire" it was the prox switches on the back of the chuck and now to seems to have fix the problem. and thanks to "ImanCarrot" for the suggestion but i can have up to 3 m code in one line with the machine but i appreciate the time and thought.
Old 04-16-2010, 08:01 AM
sinha_nsit is on a distinguished road
There is a parameter for allowing up to three M codes in one block. The usual default setting allows only one M-code.
Old 04-16-2010, 09:28 AM
firekoe's Avatar
it is nice having the ability to put up to 3 M codes on one line. I wish my
20-TA series had this feature like the my newer oi control
Universal Laser PLS3.60 stalls at boot RSlaback Laser Engraving & Cutting Machines 0 02-20-2009 09:01 PM
Need Help!- 100% jog fine, but goto stalls? Wolfesmetalfab Mach Software (ArtSoft software) 13 01-30-2009 02:40 AM
Problem- tool change stalls in high speed range productservice General Metal Working Machines 2 02-20-2008 05:52 AM
Stepper stalls, resonance, and voltage questions boyvox Stepper Motors and Drives 6 08-09-2007 04:19 PM
Spindle Stalls Out blay Milltronics 4 05-03-2007 04:55 PM
