I have tryed for 4 hours, and I could not found the parameter that will put this correct. Bassically, pressing OFFSETT/SETTING, a WORK softkey should be present (as can be seen on the pictures attached), depending on the configuration. I saw on the operator manual that the key exists, and I browsed the parameter manual and changed a few things without success. Can someone help on this? I have tryed so much that I forgot that I need dinner. Thank you. |
Does not work. I think that "fanuc-support.c" is right, and the older owner of the machine probably did not bought this extra. Thanks to all, I will how can I give the work coordinates to the machine. |
Try the other option |
| As Fanuc Support mentioned, it is an option. I also have a lathe with a 21-T control that doesn't have the work offset option, doesn't cause me any problems though. If I need to use multiple work positions (say for 1st side, then 2nd side machining) I move the position in the program, then move it back at the end. Rgds, John |
| How hard can I push a drill ? | bigtoad170 | General Metalwork Discussion | 12 | 06-06-2008 05:37 AM |
| New Machine Build- gas pipe best push out or on top | K.J.Everest@blu | CNC Wood Router Project Log | 0 | 05-03-2008 05:01 PM |
| push rod | stem fan1 | Steam Engines | 4 | 06-26-2007 06:01 PM |
| Need Simple Push Button Controller | edo | Stepper Motors and Drives | 28 | 02-02-2007 04:32 PM |
| How fast should it go, how far to push it. | jaywhy71 | WoodWorking | 9 | 11-11-2006 07:25 AM |
