Old 04-14-2010, 01:39 PM
Peloun is on a distinguished road
Exclamation Fanuc 21i Lynx Error
Hi.
We currently have a problem whit our Fanuc 21i Lynx.
The error number is : 2050
LUB PRESSURE IS DOWN OR LUBRIFICATION OIL LEVEL IS LOW. CHECK LUB UNIT AND REPLENISH THE OIL
We checked every oil tanks and they were all okay. Any idea what it could be?
Old 04-14-2010, 01:58 PM
fomaz is on a distinguished road
Normally sensors do not like oil or lubrification. Can be the sensor damaged.
Try manually to switch them and/or see any electrial changes.
If no change -> sensor is damage.
Old 04-14-2010, 02:05 PM
We found out it was related to breakers. It's seems the pump only spindle but it doesn't suck up the oil.
Old 04-14-2010, 02:14 PM
You can close this. We called a engineer to fix this.
Lynx 200 Lathe - Fanuc 21-T, how to machine lock?? Darc Daewoo/Doosan 10 12-29-2009 08:44 PM
Need Help!- Fanuc 0T error 310,320 and 520 kfmc General CNC (Mill and Lathe) Control Software (NC) 3 10-01-2008 03:49 AM
Need Help!- Fanuc OT Error 410 jgj Fanuc 7 07-07-2008 12:08 AM
FANUC OMB Error malasjo Fanuc 2 12-31-2007 05:23 AM
Fanuc 6MB Error LED tsalpha Fanuc 4 01-05-2007 08:51 AM
