Old 04-14-2010, 11:50 AM
stevo1 is on a distinguished road
Tapping parameters on Fanuc16mb
I just started a project that I have been putting off for about 2yrs now. I have a Toshiba-BP13-P6 horizontal bar with a Fanuc 16mb control on it. It was retrofitted in 07.
I have limited documentation on this machine other then the Fanuc manuals. We are having problems tapping. We are using a compression tap. It taps fine to the bottom of the hole but when the spindle reverses the Z axis sits for about 2sec before feeding out of the hole causing almost max compression on the holder. Once the tool does exit the hole it springs back releasing the tension on the holder intern bouncing the tap on the threading hole damaging the first few threads.
I ass u me this to be a parameter setting. I remember vaguely seeing something about the M05 being output when the spindle goes from CW to CCW. I found this in parameter 5101.6 and it is set to output M05. Is this my problem? I have not had a chance to trial this yet. I have compared this setting to all of my other machining centers past and present that we tap on and found they are set to NOT output M05 when going from CW to CCW.
I am also going to look at adding rigid tap on this machine. My question is what and how do I check from a hardware standpoint to make sure I can do this. IIRC I all I need is an encoder on the spindle correct?
Thanks guys,
Stevo
Old 04-14-2010, 01:27 PM
underthetire is on a distinguished road
That would make sense. The control would wait for the M5 command before continuing to the next command. Try it in air first.
Old 04-14-2010, 02:58 PM
Well I tried 5101.6 with no success.
Any other suggestions??
Stevo
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 06:43 PM
Tapping with the Tormach Tapping Head bobs_charger Tormach PCNC 0 04-24-2009 04:08 PM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 12:49 AM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 08:10 PM
