******* solved from this up to .... Trying to receive the ladder from the PMC (21-TB), before trying to send a changed version to the PMC. The controller starts to execute and hexadecimal running appears on the right side (seams that it is running ok), after a while the controller says completed. That is ok also. But on the PC side it keeps always "running" and does not go away from that. If I press "cancel" nothing was retrieved from the PMC. I have attached pictures of PC, controller at the end of transmition and controller transmitions settings. Thank you for comment. ******** this I have managed to send a new ladder from the PC to the PMC. Ladder was present on the controller, until I turn the controller off. What is necessary to make it permanent? Thank you. Last edited by fomaz; 04-13-2010 at 05:47 AM. Reason: Situation evolved |
| My understanding is that you have to write it to F-Rom in order for it to stay in the machine after reboot. Not entirely sure if this is correct for your control or your method of editing, but on i-series controls when I edit on the machine, I must write to F-rom if I wish to keep the changes. |
| This is also solved. Some information for anyone with the same issue. My control (21TB) does not let me edit the ladder on the control - or I do not know how to. I had to changed it on the PC. Using also the PC I was able to send the new ladder to the machine with RS232, and then, under "I/O ALL" changing to F-ROM / WRITE the controller "burns" the current ladder to the F-ROM, so changes were keeped! Thanks! |
| fanuc-o ladder | Bill Clark | Machine Problems, Solutions , Wireless DNC, serial port | 9 | 09-29-2011 01:35 PM |
| fanuc om-a ladder | rathi_vk | Fanuc | 2 | 06-11-2009 09:34 PM |
| ladder fanuc om-a | rathi_vk | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 01-11-2009 01:34 PM |
| New Machine Build- FANUC LADDER | CHAD LAWSON | Fanuc | 7 | 12-08-2008 12:47 PM |
| Fanuc ladder | guhl | Fanuc | 3 | 12-07-2007 12:54 PM |
