Old 04-08-2010, 11:16 PM
Splinky is on a distinguished road
Fanuc 6T spindle speed
I am working on a VDF lathe with a Fanuc 6T that had a dc spindle drive. The drive failed so it was decided to replace it with an Emerson VFD. We have it all in place and mostly functioning with one area still left to sort out. BTW the drive is commanded by a +-10 volt output from the Fanuc.
When an M03 or M04 is called with a speed of zero the spindle keeps turning CW at about 20 rpm. I have tried adjusting parameter 119 which will bring the spindle to a stop, but then the speeds in M03 and M04 are shifted by a similar amount. (M03 runs at about 80 rpm and M04 runs at about 120 when a speed of 100 is called).
I have tried doing an offset in the vfd but I end up with the same result.
Any ideas?
Thanks,
Ron
Tags
analog, spindle, vfd
Problem- Fanuc 5T Spindle Drive Speed Dragoon2 5T/5M 3 12-24-2009 08:49 PM
Need Help!- FANUC 10M SPINDLE SPEED REDUCED rchunter94 Fanuc 5 04-12-2009 10:33 AM
Fanuc 0M Spindle Speed Problem inthezone Fanuc 6 08-01-2007 04:14 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
Low speed spindle? cbass General Metal Working Machines 1 02-25-2005 03:38 AM
