Old 04-08-2010, 07:56 PM
rhutch's Avatar
rhutch is on a distinguished road
need to unlock 9000 series programs
Need to unlock 9000 series programs for outputting to pc for backup purpose from fanuc oi control. Was able to output all other programs and parameters without any issues.
Old 04-08-2010, 08:46 PM
glovebox20's Avatar
glovebox20 is on a distinguished road
On the Fanuc OM series control, You need parameter #0010 bit #4 to be a 0 to edit 9000's programs and 1 to protect the programs.
ex.
0010= 10010001 9000 Protect on
0010= 10000001 9000 Protect off.
If you have a parameter manual for the Oi control, look under the Marco programing section, it should e listed there.
If you can not edit the 9000's programs, it will not punch out the 9000's programs.
good luck
Old 04-09-2010, 02:31 AM
dcoupar's Avatar
For the 0-i, set parameter 3202 bit 4 = 0. Be aware that while this parameter is 0, you can delete the 9000 programs, too.
Old 04-09-2010, 06:15 PM
rhutch's Avatar
Thanks for the help. 3202 was the # bit#4 to 0 enable the 9000s to be output for backup. Changed back to 1 as soon as completed. Is it necessary to backup the PMC parameters also?
Old 04-09-2010, 08:18 PM
dcoupar's Avatar
3202.4 is only for 9000 series. PMC parameters should back up fine regardless of 3202.
Old 04-09-2010, 09:34 PM
rhutch's Avatar
Understood. I just wasn't sure if the PMC parameters is something I should backup or in case of a catastrophic failure, if the machine tool builder would have a copy for restoration.
Old 04-10-2010, 12:51 AM
dcoupar's Avatar
I would back up all the parameters.
Need Help!- 9000 series programs deleted. gcrudgington Bridgeport and Hardinge Mills 3 07-02-2009 05:01 PM
Need Help!- deleted 9000 series sub-programs gcrudgington Fanuc 1 06-30-2009 01:40 PM
9000 programs crazycnc Fanuc 5 12-20-2008 05:20 PM
9000 programs? jimmyjolly Fanuc 9 12-18-2008 12:13 PM
Need Help!- Punch pram's and 9000 programs Drew Fanuc 7 12-11-2008 11:07 PM
