Old 04-08-2010, 09:25 AM
TURNER is on a distinguished road
ALARM 233
Hi all,
Can anyone help with the following error. We have a fanuc 21iMB control with card reader option. This has been used many times, but now is throwing an error:- 233 Bp/s alarm. Everything is being set as we have done many times before ie I/O device=4 etc. This alarm is firing as soon as we insert the card into m/c. Any ideas ???
Cheers, Keith
Old 04-08-2010, 10:52 AM
dcoupar's Avatar
Is parameter 0110 bit 0 set to 0? If it's 0, then parameter 0020 sets the device for both input and output. If it's 1, parameter 0020 sets the input device and 0021 sets the output device (for foreground edit). Maybe someone changed this?
Old 04-09-2010, 07:30 AM
Hi, and thanks for the reply dcoupar, the parameters you spoke of look fine. Maybe its broke, will have to get fanuc out. Just thought id check on here first to save the cost. We have 3 m/c's set the same cant see any thing thats been altered.
Keith.
Old 04-10-2010, 10:33 PM
not an expert is on a distinguished road
Does the 233 alarm say device busy?
If so there is a setting on the PMC side of the control called online monitoring. It uses an RS-232 port. I would turn that off before calling OEM.
Old 04-18-2012, 02:53 AM
Jung is on a distinguished road
Smile
hi not an expert: you are expert
Old 05-13-2012, 10:06 PM
susam1965 is on a distinguished road
Red face turn on/off online monitor with rs232
fanuc 18T system
1.setting pwe=1 , MDI mode ,
2.system---PMC----soft right(next page) key----online----rs-232c(used/not used)
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Problem- Alarm 350, not in my alarm list, any ideas? ralph@nes Mazak, Mitsubishi, Mazatrol 4 09-27-2008 01:14 PM
