| Hi guys, I´ll take the opportunity to ask you something: We are implementing DNC-Max here and I know it has a ton of translators to do almost anything... I´m transfering some headers to a Fanuc 0i-TB and I´m having problems to get the : character at the control side... The port in my DNC software is set to operate in ASCII mode as well... If I send this: % O7999 (PN:B112229-1 # REV. PN:A # FIX:1) N20 (MAQUINA:ATOC II) N30 (CONTROLE CNC:FANUC 0I-TB) N40 (PROGRAMA:2079990) N50 (ID ANTERIOR:WT3-2065.VTG) N60 (CODIGO DE APLICACAO:0) N70 (DESCRICAO:CORPO CONECTOR) N80 (PART NUMBER:B112229-1) N90 (REVISAO PART NUMBER:A) N100 (PART INFO:B112229-1) N110 (REVISAO PART INFO:B) N120 (OPERACAO:USINAGEM F1) N130 (FIXACAO:1) N140 (PROGRAMADOR:dANIEL SANTOS) N150 (*************************) N160 G00 X1000.0 Z2000.0 N170 M30 % I get this at the control side: % O7999 (PNOB112229-1 # REV. PNOA # FIXO1) N20 (MAQUINAOATOC II) N30 (CONTROLE CNCOFANUC 0I-TB) N40 (PROGRAMAO2079990) N50 (ID ANTERIOROWT3-2065.VTG) N60 (CODIGO DE APLICACAOO0) N70 (DESCRICAOOCORPO CONECTOR) N80 (PART NUMBEROB112229-1) N90 (REVISAO PART NUMBEROA) N100 (PART INFOOB112229-1) N110 (REVISAO PART INFOOB) N120 (OPERACAOOUSINAGEM F1) N130 (FIXACAOO1) N140 (PROGRAMADORODANIEL SANTOS) N150 (*************************) N160 G00 X1000.0 Z2000.0 N170 M30 % Settings at the control: STOP BIT 2 NULL INPUT (EIA): NO TV CHECK (NOTES): OFF TV CHECK: OFF PUNCH CODE: ISO INPUT CODE: ASCII FEED OUTPUT: NO FEED EOB OUTPUT (ISO): LF I want to get at the control side the ":" characters that there exists in the original file... is that possible in a FANUC control? Is there any hidden bit to do that? ![]() Thanks in advance,
__________________ Kind Regards Daniel - Camfun |
| Colon is not available on Fanuc. Replace it by some other character. I normally use @ character for such applications. @ becomes available through C-EXT soft key. edit: set param 3205#0 (COL) to 1, to see a colon as a colon. Last edited by sinha_nsit; 04-10-2010 at 03:30 AM. |
| Hmmm. I have the colon sign in some of my programs on the 15, and 18 series Fanuc in the notes. I have not checked on the other controls. I could not find a parameter setting in the Om control that would not allow or disallow the colons. IIRC I had a similar problem some time ago. It may be your DNC settings. There was a setting that would change the : (colon) to and O (letter O) before the program number. It maybe that this setting is replacing your : with O’s. It’s worth a look. Stevo |
| Sinha, I apologize that I was not more specific. I do not have a key to type in a colon at the control. I can however use a colon when writing a program and download it to the control with no problems. So I ass u me that if this is possible on the 15, and 18 series control that I checked it should certainly work on the newer then those Oi control. I think that it is just too much of a coincidence that it is replacing the colon with the letter O considering the : and O are the 2 ways Fanuc identifies the program number. I would check the software to see if there is a setting for replacing : with O. Stevo |
| Problem- DNC missing characters! | Place2809 | Machine Problems, Solutions , Wireless DNC, serial port | 8 | 08-11-2009 07:57 AM |
| how to have more than 32 characters in one block | sinha_nsit | Fanuc | 3 | 04-01-2009 12:25 AM |
| Bad Characters | gplush | Haas Mills | 5 | 02-08-2008 11:00 PM |
| fanuc program comments | Rich 72 | General CNC (Mill and Lathe) Control Software (NC) | 3 | 09-04-2007 07:38 AM |
| How do I enter comments into a Fanuc OiM? | Darc | Bridgeport and Hardinge Mills | 4 | 02-09-2005 07:42 AM |
