Results 1 to 8 of 8
Thread: Control will "punch" but not "read"
    Mar 2010
    Control is a fanuc 3m. It will consistently punch programs from the control to the PC, but will not go the other way. Is there a way to check the RS232 port on the CNC? I have a lighted 9 pin box between the pc and the CNC everything looks good there. I shows data coming in when punching, and data going out after I hit input on the control (I have "wait for XON" enabled). The control however just blinks LSK and never registars a new program number or writes the program to memeory. There are no alarms generated. I also know that the cable form the PC to the CNC is good. Can anyone suggest a repair company? I may have to send the main board off to be repaired.
    Dan
    Registered dcoupar's Avatar
    Mar 2003
    Hi Dan,
    3 questions:
    1. Where are you located?
    2. Have you tried sending back the same program you punched out?
    3. What software are you using to send/receive?
    Mar 2010
    I am in central Washington State.
    I have tried sending exactly what was punched (it puts a &he:% at the top/first line of the program).
    I am using NCnet-lite from cadem.
    I was thinking of pulling the main board, and tracing the circut from the RD pin of the honda connector (pin 8 or 9 I cannot remember). Maybe I have a bad connector or loose solder joint or something. What do you think? Have you ever seen a serial port go "half" bad? I have only seen them work, or not work.
    Thanks,
    Dan
    Dec 2003
    The hardware handshake can go bad for either send or receive.
    If you have the hardware pins connected, i.e. full complement cable, it could also be your PC.
    I generally use a 3 wire cable with the H.S. jumpered out as although Fanuc has to see the H.W. signals, they do not use them for data control, just the XON/XOFF.
    Also, on some controls, the % sign indicates end of transmission or turn tape off.
    This is the 6m but the pin out is the same.
    Attached Thumbnails Attached Thumbnails Control will "punch" but not "read"-fanuc-6m.pdf
    Mar 2010
    Al,
    Thanks for the info! The cable I made has a 20 pin male honda one one end and a female DB-9 and is wired lke so:
    Honda----------------- 9 pin
    9 (SD) ------------- 2 (RD)
    8 (RD) ------------- 3 (TD)
    17 (SG) ------------- 5 (SG)
    on the fanuc side I joined:
    5 (ER)--
    18 (DR)--
    16 (CD)--
    and:
    19 (CS)--
    20 (RS)--
    On the PC side I joined
    1 (DCD)--
    4 (DTR)--
    6 (DSR)--
    and:
    7 (RTS)--
    8 (CTS)--
    Does that seem correct to you too? The programs I have tried to send start and end with a %. Does there need to be a LF or CR after or before the program? Seems like I remember dealing with a control like that one time.
    Dan
    Dec 2003
    Looks about right, this is where a break-out box comes in handy, you can see the status of the ports on the LED's.
    Most electronic component stores have them, they are usually under $20.00
    Mar 2010
    I have one. I have put it in between the pc and the cable. It shows data going to and comming from the PC. Pins 2 and 3 are all I really watched.
    One strange thing though. I always make sure that I have the CNC powered on before I power on the laptop. It seems to help with any port initialization problems. Anyway when I first start everything all the lights are green (except RI and GND, they are not on at all). After I send a file to the laptop some lights stay red. It is able to recieve another program so I assume that this is normal.
    I have tried to send a program to the CNC after startup thinking that somthing was not being reset, but I got the same results.
    Dan
    Mar 2010
    Does anyone know of a way to test the 20 pin honda socket on a main board?
    1. Replies: 12
      Last Post: 06-27-2012, 07:30 AM
    2. Need Help!- "motor steps per resolution" and "driver microstepping" settings
      By margni74 in forum LinuxCNC (formerly EMC2)
      Last Post: 10-24-2009, 03:33 AM
    3. "J" head type "millport"(tiwan,1980) clutch
      By marksbug in forum Bridgeport and Hardinge Mills
      Last Post: 08-17-2009, 11:48 AM
    4. Need A Quote- 304SS Tube 3" (1/16 wall) x 19.5" Cut-Off, Turning, Drill or Punch
      By onecoolone in forum Employment Opportunity
      Last Post: 11-19-2008, 09:17 AM
    5. Has anyone looked at the "JET" or "Shop Fox" manual machines?
      By boosted in forum General Metal Working Machines
      Last Post: 03-04-2007, 10:33 PM
