Old 04-02-2010, 09:47 AM
shredder is on a distinguished road
fanuc 16m ext offset
Does anyone know what parameter I need to change to get my 16m g54 ext offset
to stop zeroing on startup,I would like to be able to store offsets there and not have it go back to zero on startup?
thanks
Old 04-02-2010, 11:57 AM
dcoupar's Avatar
I believe it's #1201 bit 2 (see attached).
Name:	F16 Local Offset Canceled by ZRN.jpg‎
Old 04-02-2010, 04:12 PM
thank you for your help,I will try this and tell ya if it works.
thanx again
Old 04-10-2010, 09:30 AM
I tried this and it still goes back to zero on reboot?
Old 04-11-2010, 10:40 PM
sinha_nsit is on a distinguished road
What do you mean by G54 ext offset?
Ext offset, G54 offset, G55 offset ... all are different.
Do you mean geom/wear offsets which are normally cleared by RESET?
Old 04-16-2010, 02:47 PM
I mean the ext offset clears to zero on reboot
Old 04-16-2010, 06:45 PM
dcoupar's Avatar
You mean this one, correct?
Name:	16M EXT Work Coordinate.jpg‎
Old 04-17-2010, 12:44 AM
Ext offset clearing to zero upon reset is unexpected. There might be a parameter setting which I am not aware of.
Old 04-17-2010, 02:19 PM
Yes thats the 1 dcouper
Old 04-22-2010, 10:24 PM
ANyone?????
  #11   Ban this user!
Old 04-22-2010, 11:59 PM
dcoupar's Avatar
I've run out of places to look for the solution to your problem.
For now, you could add a couple of blocks at the beginning of the program to "preset" the EXT offsets:
O1234
G10 L2 P0 X-12.3456 (X-EXT VALUE)
G10 L2 P0 Y-2.3456 (Y-EXT VALUE)
  #12   Ban this user!
Old 04-23-2010, 07:51 AM
Better still, set ext offset to zero and repeat the work-offset-setting process (or, if the ext offset values are known to you, just increment/decrement the G54 (etc) offset values by those values). Do you really need to use ext offsets?
Fanuc tool offset behaviour cdmurphy Fanuc 3 12-14-2009 11:37 PM
Fanuc 16i variable offset issue PCCDon Fanuc 3 11-26-2009 01:04 AM
FANUC 3M G54 OFFSET, H-OFFSET----Please help!!! cjchands Fanuc 2 05-25-2009 11:22 AM
work offset in fanuc 6m b- help rags Fanuc 14 08-03-2006 09:39 PM
FANUC 18i Offset AKamil G-Code Programing 0 08-07-2005 02:56 AM
