Hi all, I am in the process of getting an old Leadwell VMC connected to my laptop. I have worked through most of the problems, and I can now send programs from the CNC to the laptop. However I cannot load a program from the laptop to the CNC memory. Here is what I have done or checked so far: The cables: Fanuc Honda Fanuc DB-25 9-------------------------2 8-------------------------3 20-------------------------4 19-------------------------5 18-------------------------6 17-------------------------7 16-------------------------8 5-------------------------20 Yes, I had to rewire both ends of the factory cable. I am not sure why it was wrong, some people sould not be left alone with a soldering iron! Anyway I found the pin outs for the honda here on this site for a 6M, and they were also in the maintenence manual. Fanuc DB-25 9 pin serial 2----------------------------2 3----------------------------3 7----------------------------5 4-5 6-8-20----------------------1-4-6 I have tried all the combinations for the 6-8-20, 1-4-6. Ie some say not to hook them together some say do. All the combinations work for me, there was no change. I can still only send from the CNC to the laptop. I am using Cadems NCnet lite free software. It is set to 4800, 7, e, 2. I have tried different flow controls right now it is set to none. I also checked the system page on the laptop and set the port FIFO settings the same as the software. I also slowed the baud rate down. No change, just slower. Parameter 005 is 10000011. Some where I read that parameter 0014 needs to be set a certain way, but my book says that 0014 is only used if the I/O is set to 1 whid it is not. TVON is 0 I/O is 0 EIA / ISO is 1 I cannot find the problem. Unless it is a cable problem, but I have ohmed them twice and all seems well. Any thoughts, guesses or comments are welcome (needed...please ![]() Thanks in advance, Dan |
Tonight I rechecked my wiring, and all is good. By stopping the software before the file is transfered I can get the control the through a 086 alarm wich is a data ready signal lost during a rs232 input. So I guess something is getting throught. Maybe I have a program format problem? Also when I out put a program from the control, i get this: &he:% :2222 G00 G90........ The &he: I have not seen before. I have tried sending programs as output with the &he: and with it removed. I changed the : to an O. I added an empty line to the top of the program. Nothing seems to work.....yet. Any ideas? Dan |
| Yasnac i80, Rs232 problem | dewcnc | Machine Problems, Solutions , Wireless DNC, serial port | 8 | 02-18-2011 12:03 AM |
| Com Problem RS232 | bigalow | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 04-24-2008 11:16 PM |
| Problem- RS232 to Fanuc problem | rchunter94 | Fanuc | 2 | 04-23-2008 08:01 PM |
| Problem with RS232 | giorgis | Fanuc | 6 | 01-21-2008 06:01 AM |
| Rs232 Problem | j-radkemachine | Haas Mills | 1 | 10-06-2006 10:03 AM |
