Old 03-29-2010, 04:16 PM
lmostafa is on a distinguished road
Fanuc 0i help
hi i need hep
fanuc OI TC alarm 1420
Old 03-29-2010, 11:51 PM
dcoupar's Avatar
This sounds like a MTB alarm. What make / model of machine is it?
Old 03-30-2010, 05:36 AM
the machine is HWACHEON HI-TECH200B
alarm 1420 tool presetter position alarme
thanks
Old 03-30-2010, 06:27 AM
dcoupar's Avatar
I don't have any documentation on this machine, but I would guess that the alarm is being generated by the tool presetter "up" switch. You should be able to locate the input for that switch (Xnnnn.n) on the electrical drawings and check the diagnostics to see if the switch makes when the presetter is up.
On a Doosan P240, the input is X0005.7 for Q-Setter arm UP and X0004.6 for arm down. You can go to SYSTEM, [PMC], [PMC DGN], [STATUS] then key in X0005.7 and press [SEARCH]. Operate the presetter and watch the bit to see if it changes 0 to 1 when the arem goes up. If not, the switch or arm may need adjustment.
Old 03-30-2010, 04:36 PM
thanks
when i push button indexagage of Tourette the alarm 1420 coming
Old 03-30-2010, 11:56 PM
Ozemale6t9 is on a distinguished road
Are you trying to index the turret with the tool presetter arm in the down position? A lot of MTBs disable turret index with arm down so the turret can not index into the arm. This usually generates an alarm if you try to index the turret with the arm down.
Old 04-02-2010, 07:54 AM
hi all
iam teste the input clump unclump turete X5.6 and X5.7 in SYSTEM, [PMC], [PMC DGN], [STATUS] is ok .
iam backup fils sram to the cnc but the alarm is Current
Old 04-10-2010, 03:52 AM
hi all
i thank you to mach
dhe alarm (1420 tool presetter position )in machine HWACHEON HI-TECH200B
is only dhe cover touchprobe is opened .
if any man want a document fanuc OI Mmat ,send me a email in :lmostafa@hotmail.fr
or:lmostafa16@gmail.com
i want a Fanuc 6MB manual pleas send it mi in my email. thanks
thanks too much.
Old 04-17-2010, 03:16 AM
hi all
i need a document manual maintenance fanuc OT OM send it me by email:lmostafa@hotmail.fr
thaks
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
