I have a Mori-Seiki MV-45 mill with a Fanuc 10M controller and communicate via RS-232. I would like to copy all the machine parameters to the PC for backup purposes and don't really know how to accomplish the task. Any help would be much appreciated - Thanks. |
| OK - Thanks for the help. Using the same software (EditCNC) I use to transfer programs back and forth, I was able to receive some data by following the sequence outlined (SERVICE - PARAM - PUNCH - ALL). Here is a sample of what it looks like. There must be a couple of hundred lines with nothing but "P0" plus a bunch of other "stuff" that does not look like what I would have expected. Anyway, I guess my question at this point is; does data in this format look correct? I need to replace the backup batteries and want to feel comfortable that I've accurately copied all the parameters in case of the freak power failure while the batteries are out. Thanks again! P9 P1 P2 P9 P1 P2 P9 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P00000000 A1P00000000A2P00000000A3P00000000A4P00000000 A1P1000A2P1000A3P1000A4P999999 A1P-801000A2P-461000A3P-511000A4P0 A1P0A2P0A3P0A4P0 A1P0A2P0A3P0A4P0 A1P0A2P0A3P0A4P0 A1P0A2P0A3P0A4P0 A1P6A2P116A3P0A4P0 A1P0A2P100A3P0A4P0 A1P6A2P116A3P0A4P0 A1P1A2P1A3P0A4P0 A1P114200A2P27000A3P0A4P0 A1P0A2P0A3P0A4P360000 P00000000 P00000000 P10000000 P00000000 P00000000 P00000000 P0 P0 P0 P5 P775 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P3 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P0 P00100100 P00000001 P00000000 P00000000 P50 P0 P0 P0 P0 P0 A1P0A2P0A3P0A4P0 A1P0A2P0A3P0A4P0 A1P0A2P0A3P0A4P0 P00000110 P00000011 P100 P100 A1P0A2P0A3P0A4P0 P0 P0 P0 P0 P0 P0 P0 P00000000 P0 P0 A1P0A2P0A3P0A4P0 A1P0A2P0A3P0A4P0 P00010000 P00000000 P00000000 P00000000 P00000000 P00000000 P00000000 P00000000 P00000000 P00000000 P00000000 P0 P0 P0 P0 P0 |
| make sure you write down the parameters in the 9000 range, they may not be saved with the download. You also should save the keep relays, timers(counters?) and ball screw compensation parameters(if any data is set). |
| Thanks Fellows - I'll be sure to manually record the "9000" parameters, keep relays, timers etc.. By the way, does the data in the sample look like what you've seen before? Still not sure about all the lines of "P0", and I'm wondering if the data would look the same if a different software was used to transfer the parameters to a .txt file. |
| Some thing does not look right to me. Usually the parameter line is preceded by a Pxxx Nxxx etc. Al.
| Al is right. I just looked up a few backups I have and they all started with Nxxx. That indicated which parameter #, and the P was the the setting of the 8 bit string, and Ax was each of the available axis in the controller. I would check the output of parameters again. As you are saving parameters it is always a good idea to save any macro programs as well. The 0's for values are ok. They are parameters that are not set Last edited by andyb4; 03-30-2010 at 11:27 AM. Reason: added |
#10
| I think I've got it now. I punched the parameters once again and the resulting .txt file does have "N" prefixes for all the lines. Like an idiot, I "stripped" the line numbers the first time around as I thought the software I used to transfer added them as if you were numbering or re-numbering a CNC program. Now I can look at the backup file and it makes sense and I feel better about it. I also recorded the "9000" parameters, data for the timers / counters and keep relays. You guys have been a big help and I really appreciate it! |
#11
![]() Al.
| Need Help!- fanuc 10 m (parameters) | maher | Fanuc | 6 | 12-20-2011 02:37 AM |
| Need help with PC Parameters on a Fanuc 6M | jimlinn | Fanuc | 39 | 02-15-2011 10:59 AM |
| Fanuc 6MB - Can't set parameters - Help | eriksalo | Fanuc | 1 | 03-12-2009 01:34 AM |
| Need Help!- Parameters for fanuc 0T | Mrmendiola | Fanuc | 3 | 10-27-2008 11:03 AM |
| Fanuc 0-T Parameters | rrbmachining | Fanuc | 3 | 09-08-2007 03:42 AM |
