Old 03-27-2010, 07:44 AM
alexbelen7 is on a distinguished road
Fanuc Series 0-C Memory Board Replacement
I don't know how to replace this board...the newly arrived memory board has no IC's on its socket...does anyone has a procedure? need your help guys thanks!!!
Old 03-27-2010, 10:00 AM
andyb4 is on a distinguished road
First, if you still can, make a back up of everything. Parameters, programs, macro programs, etc. The new board will need the chips from the original board. gently pry the chips from the socket, careful not to bend legs, and insert it into the same socket on the new board making sure it is oriented the same way. There is a dimple on one end. Exchange all chips that are in sockets. If there are any jumpers, they will have to be set to the same as the old board. You will then have to load in your back up parameters, programs etc. May need to set up communication parameters manually to upload backup. Document all as you go. Hope this helps.
Old 03-27-2010, 05:31 PM
Thumbs up
this is a lot of help thanks!!! I just hope I do it right...hehehe...thanks again!!!
Old 05-05-2010, 08:28 AM
memoryman is on a distinguished road
Don't forget: the serial port is an option on the 0 series, so load your option parameters before the communication parameters.
Bill
Need Help!- Amada Pega 244 w/ Fanuc 6m B controller memory replacement MetalForce Fanuc 10 08-10-2011 04:14 PM
FANUC P25 Base 2 Board for Series 15 gbowne1 Fanuc 3 01-22-2010 10:32 PM
Help on Realtime board replacement sunnybank Cincinnati CNC 2 10-13-2009 02:10 AM
OKUMA BOARD REPLACEMENT. GPena Okuma 4 10-02-2008 01:35 PM
Help - board replacement adamromero Machine Problems, Solutions , Wireless DNC, serial port 0 08-09-2007 01:54 PM
