Old 03-24-2010, 07:40 PM
javierb181 is on a distinguished road
MORI SL3 Fanut 11
I have a sl3 with fanut 11 who has trouble moving one referenciarce without holding down the joystick can someone tell me what the problem??? I am in despair
Old 03-24-2010, 08:10 PM
Mori sl3 FAnut 11
have troubles whit my MORI SL# who has a FANUT 11 controler, the probles is, when i wont to set the cero, i move the joystick, but when i relese de joy, he doesent stop and hit the back part.
some one have idea what is the problem??
Old 03-25-2010, 03:34 AM
CNCZILLA's Avatar
CNCZILLA is on a distinguished road
If i am interpreting your problem correctly it sounds like you may not be referencing the machine correctly. To reference place the machine in Home Mode. Your machine will reference in the + direction toward the spindle, so hold your joy stick in the - direction, you will notice the axis move slightly in the - direction and then reverse in the + direction to home but you must hold the joy stick the whole time until reference is complete then you can let go of the joy stick. Do it this way for each axis. If you do this and you see the machine reverse directions to home but then the axis keeps moving until it overtravels you may have a bad reference limit switch or the dog is not making contact with the limit switch. You should be able to see this switch in your inputs on the screen to verify if the bit changes when the dog makes contact with the switch. Good Luck
Mori and DMG underthetire Mori Mills 3 02-05-2012 03:29 PM
Mori SL1 jkoper AjaxCNC Control Products 0 06-20-2009 03:13 PM
Mori SL-2 JMECKES Mori lathes 2 10-31-2008 07:06 AM
MORI Mori G-Code Programing 7 07-07-2008 12:16 PM
