Old 03-24-2010, 06:08 PM
jeffm is on a distinguished road
Alarm 2051
How do I fix this alarm 2051 its tail body over travel and now nothing moves?
Old 03-24-2010, 07:45 PM
dcoupar's Avatar
What machine and control?
Old 03-25-2010, 03:42 AM
CNCZILLA's Avatar
CNCZILLA is on a distinguished road
If your alarm is indicating tailstock overtravel then you need to find the input for this switch in your electrical prints and look in the inputs on the machine and see if it is made or not. It could be the switch is bad or maybe the tailstock went on the switch and someone has physicaly moved it off but the switch stuck closed due to being gummed up or something. The machine is probably inhibiting any axis movement because it thinks the tailstock is in a position to interfere so it woun't let you move anything as long as this alarm is in effect.
Old 03-26-2010, 10:12 AM
Its a Doosan with a Fanuc Oi. I just did it to old fashioned way I attached a strap to the live center and the chuck and moved the quill to pull it off the switch
Old 03-27-2010, 02:32 AM
dcoupar's Avatar
So you've resolved the problem?
Old 03-28-2010, 10:57 PM
sinha_nsit is on a distinguished road
There can be an MTB-defined M-code, to ignore the position of the tailstock (e.g., whether extended or retracted). On my machine, it is M83.
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Problem- Alarm 350, not in my alarm list, any ideas? ralph@nes Mazak, Mitsubishi, Mazatrol 4 09-27-2008 01:14 PM
