Old 03-24-2010, 10:15 AM
bruiserba is on a distinguished road
thread turning fanuc 10te
i am trying to turn a npt 1/2-14 thread using 7/8" stock the code im using is N115 G76 X0.73 Z-0.85 D50 K0.07 I-0.0265 F0.07143 .i keep getting double threads am i doing something wrong can some one help me out the machine is a miyano with fanuc 10te controls. thanks so much for any help.
Old 03-24-2010, 10:41 AM
Manosteel503 is on a distinguished road
does that only take single line g76 or can you try double line
Old 03-24-2010, 11:01 AM
what do you mean by a double line i dont know.
Old 03-24-2010, 07:25 PM
dcoupar's Avatar
I believe that most Fanuc 10T controls are set up to use a 2-line G76. It would look like:
G00 G97 X0.9829 Z0.2143 S517
G76 P021060 Q20 R0.002
G76 X0.7382 Z-0.5337 R-0.0234 P536 Q80 F0.0714
Have you threaded on this machine before without problems?
What RPM are you running?
Is G97 (CSS Cancel) active?
Old 03-24-2010, 07:30 PM
CNCRim's Avatar
remove D50 then it should work.
Old 03-24-2010, 07:44 PM
dcoupar's Avatar
D50 is the depth of first pass. It's required for a 1-block G76.
Old 03-25-2010, 06:10 AM
dcoupar would you post a sample prog using that double line so ill know what numbers goes in the p's and q's id like to try it .we never have cut threads before on this machine rpm 1000 were using g97 thanks for the help.
Old 03-25-2010, 07:19 AM
dcoupar's Avatar
The sample I posted earlier should be close. Here's an explanation.
Old 03-25-2010, 10:11 AM
sinha_nsit is on a distinguished road
What you mean by double threads: double-start or double pitch or something else?
Possibly, you are calling G76 twice, with different tools/rpm/start-point.
Old 03-26-2010, 10:17 AM
what i mean by double threads is it looks like the lead dont repeat .when it makes a second pass it dont stay in same groove .
  #11   Ban this user!
Old 03-27-2010, 01:01 AM
The subsequent threading passes automatically shift laterally by required amount, such that only one side of the tool cuts the groove. This happens in roughing passes. Finishing passes do not shift laterally.
If, due to some reason, you do not want a shift in roughing passes, replace 60 by 00, in the P-word (first block of G76).
Turning a custom thread w/G33? SRT Mike General Metalwork Discussion 3 10-31-2007 10:42 PM
turning 1/4-20 internal thread Runner4404spd Mini Lathe 3 09-20-2007 01:43 AM
FANUC 10TE RAM problem guhl Fanuc 7 08-01-2007 11:10 AM
Need help with live tooling on a FANUC 10Te/f kangarabbit Fanuc 4 03-30-2006 03:05 AM
turning thread Q Shizzlemah AjaxCNC Control Products 0 02-25-2006 02:34 PM
