03-20-2010, 09:42 PM
Ikegai AT20U Fanuc 6T problems | | Hello,
I bought this lathe for a good price, they said nothing was wrong, But i didnt believe them, anyway.
I powered it up and most everything worked good, I was able to get all the alarms to clear and do most everything through the MDI.
I can get the all the axis to "home" but the spindle I could only get to orient one time?
Also when I do a tool change the turret will usally make a change if you only go one slot, But if you do multiple slots it trys to retract with the turret still going in fast mode and slams the "pocket" but keeps going around then it does this about 3 time and then errors out.
Would this be a bad prox probe causing the control not to go to slow speed?
I jumped the extend/retract output and the slow and fast turret rotate outputs and they all seam to work fine.
I apreciate all the help from everyone here.
Thanks |
