| When you are in the POS screen do you have sofkeys for ABS, REL etc. You should be able to select the ABS then zero that. I am tied up at the moment(not by the wife) but when I get a change to get out to my control I will take a look at the sequence for doing so. Stevo |
| Ok I got untied for a few moments and ran out to the machine. There appears to be no option to “origin” the ABS coordinates. You can only origin the REL. Out of curiosity why do you want to origin the ABS position? The absolute is the position around the work coordinate that is active and really means nothing once you set it to 0. Why can you not use the REL position to clear out? IIRC you could origin the ABS and REL on the 10 series and even the 15series. I can’t check now because I have the 15 tore apart and the 10 is long gone. I did a quick scan through the manual and did not see anything referring to being able to zero the ABS but it did mention the REL position. Best guess is you are stuck with only being able to origin the REL. Stevo |
| Yeah, well I wanna use fixture offsets that are relative to part zero not the machine table zero. So being able to zero out the absolute scale is necessary for me, I could just G54 X Y to the fixture offset and put that value in the offset page, but we have templates for our main programs that I would like to continue using else, I have to re-enter the coordinates on every part i make because we took the vise out or something. |
| I believe if you set the (EXT) Work Coordinate to the part zero, your other Work Coordinates will be based on that. So if you locate part zero at machine coordinates of X-24.5 Y-12. for example, put those values into the (EXT) Work Coordinate. |
| in your position screen hit the soft key that enables "all" place your tool at your required x and z 0 position. it's done incrementally. hit "u" and origin should show up above one of the soft keys. do the same for z with "w". This works for manually moving your axis around. there is also a measure button to use when setting your work offsets. PB |
#10
This is what I'm doing now for a work around. I thought the EXT was just another way of positioning all fixture offsets from origin. So i usually leave this blank and G54 blank. And have the machine know 'internally' where i set my origin. But yeah your right, entering in the values to part zero lets me use my fixture offsets from part zero. |
#11
u is incremental movement for x (x is absolute movement ie x2.5 is 2.5 inches in diameter and u2.5 would move the x axis up 2.5 inches). w is incremental for z and v is incremental for y. With the position screen showing three (Machine, Absolute and cannot remember the other) press u and the top left x(u) value will flash and "origin" will appear above one of the soft keys. I hope this helps explain things a little more. PB |
#12
I guess I am a bit foggy on what exactly you are trying to do and why. If you have to take your fixture off of the machine and put it back on you must pick the fixture back up again so you know where it is at. Why would you just not set G54 or any other work coordinate equal to that position and let it rip?
Stevo |
| Need Help!- How do you change a Fanuc 15M Linear Scale Interface | Mikeado | General Metal Working Machines | 1 | 09-29-2009 11:43 AM |
| Fanuc 0i-MC absolute arc center | PinnacleMachine | Fanuc | 5 | 08-07-2008 10:52 AM |
| Need to make scale tire mold for 1/6 scale car | thuffner3 | Moldmaking | 2 | 04-29-2008 12:57 AM |
| Fanuc 11M Absolute position probs | trotsky | Fanuc | 0 | 11-05-2007 01:29 PM |
| How do we get absolute to Zero?? | Fine01 | Fanuc | 1 | 10-23-2007 08:55 AM |
