Results 1 to 11 of 11
Thread: Setting up a Fanuc 6T system
    Registered Snowie's Avatar
    Jul 2008
    NZ
    Red face Setting up a Fanuc 6T system
    Hi all
    Just looking for a but of guidance with setting up my Lathe with a 6T Controller.
    I'm have a issue of the G50 cmd not holding the correct location after you do a manual jog or handle operation. After doing a bit of hunting i found a post in this forum 'Absolute cords reset in handle mode'.
    I'm wanting to know if my lathe is set up for abs or inc programming by default. What parameter address do i look at to find the setting of this data bit and what to change it to to set it to abs mode.
    I tryed to run a G90 in the midi but that put's it into cutting cycle mode not ABS mode
    Cheers
    Snow
    May 2007
    south korea
    Hi Snowie,
    You have to set "1" DGN 104.1(ABS) by "Manual absolute"switch ON.
    You can confirm at diagnosis screen.
    DIAGNOSIS
    NO
    104 * * * * * * 1 *
    Good luck!
    Jul 2008
    NZ
    Thanks for that. Had a quick look and bit 1 is set to 0. Will set it tomorrow
    Will keep you posted.
    Is there a way to do this with a gcode? G90 special
    Ta snow
    May 2007
    south korea
    No, you can't set this bit by G-code.
    You can set by switch operatoin.
    Jul 2008
    NZ
    Hi
    Just checking bit 5 of address 104 is the H/L handle switch Correct??
    Umm the next thing... How in the gigger do you change the setting to ABS from INC???
    I don't have a "Manual absolute" Switch on the operators console. Is there a parameter i have to change?
    Snow
    May 2007
    south korea
    Do you have Electric circuit drawings and PLC ladder diagram?
    Who made the lathe?
    And could you send me Parameter list NO.0~No.4?
    Jul 2008
    NZ
    Hi
    Lathe is a Ikegai AX-20N. I have alll the manuals Wiring diagrams. Fanuc programming manual and the Ikegai users manual.
    I maybe stupid, but the Fanuc programming manual sucks majorly with descriptions. However it might be because the lathe is in INCR mode so that is why the cmd's arn't being processed.
    Parameters as requested
    address
    0000 10110110
    0001 01101101
    0002 11101010
    0003 10111000
    0004 00000000
    Cheers Snow
    May 2007
    south korea
    Could you send me electric circuit drawings and PLC ladder diagram?
    You can command INC movement by U654.321 and W123.456,
    and ABS movement is X123.456 and Z654.321.
    Good luck!
    Aug 2008
    Ikegai FX-20
    Snow,
    Nice machine - Ikegai made a good product.
    Fanuc controls should be set up to operate in the absolute mode normally. To program an absolute move after homing the machine use X and Z. To program an incremental move use the letters U and W. You can intermix them freely and might find it convenient to approach the part in absolute, then do the cutting in incremental, then go back to the turret index point in absolute. It is pretty straightforward after a few tries.
    Good luck.
    Warren
    www.uptimecorp.com
    Jul 2008
    NZ
    Hi all.
    Thanks for your replys. Just an update. Sounds like a manual/ absolute mode problem. I'm having a guy to swing in to take a look. Apperantly the older machines don't have the switch on the operators console as mentioned before in this post. Will keep you posted
    Jul 2008
    NZ
    Hi all
    Just a update. I'm all going now it was a pc parameter 3001
    Many thanks for your help
    Snow
    1. Need Help!- Fanuc parameter setting
      By samiahmed in forum Fanuc
      Last Post: 02-19-2010, 12:27 AM
    2. Fanuc 3T pulse setting
      By Nandop in forum Fanuc
      Last Post: 09-26-2009, 06:03 AM
    3. Need Help!- Setting tools offset on Fanuc 21i
      By jdgromi in forum Fanuc
      Last Post: 01-08-2009, 06:04 AM
    4. simens 840D system parameter setting
      By a_ravi_tn in forum G-Code Programing
      Last Post: 04-16-2007, 10:39 PM
    5. Replies: 0
      Last Post: 03-03-2006, 07:50 PM
