Old 03-09-2010, 09:45 PM
robertbair is on a distinguished road
Machine Crasher
I have a Yang ml-15 with a fanuc ot controller. Machine crashed and ive cleared and reinstalled all parameters. Now when i try to zero return the machine i get alarm code 510 over travel. So machine is stuck in the middle of the travel and it wont go home. Is there an easy parameter fix? When i use the handle i get 510 in X and 520 in X.
Old 03-09-2010, 10:10 PM
dcoupar's Avatar
Try this:
Power down the control.
Press and hold the P and CAN keys while restarting. Wait until it's done and let go of the keys.
Try to zero return.
Old 03-10-2010, 07:07 AM
Thanx
I will try today and let you know tonight.
Old 03-14-2010, 10:16 AM
zavateandu is on a distinguished road
Wink
hi
this is very simple porblem to solve
i already wrote this before but i will say again for u
make pwe =1 than go on parameter 700 for x and 701 for y and write down the values.
then type 999999 on 700 and 701
after that go on home and try to send the machine on reference.
u will see that machine gets the origin
make the same on Y axis
after that go back on param 700 and 701 and put back the values that were before.
make the PWE=0 and u problem is solved
GOOD LUCK
Old 03-14-2010, 10:34 PM
Thumbs up Thanx
Thanx for the info.
Always very helpful at the CNC ZONE!
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Another machine rigid tapping (stepper machine) samco LinuxCNC (formerly EMC2) 10 04-10-2009 07:21 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
