Old 03-08-2010, 09:57 PM
gabedrummin is on a distinguished road
SOS dead OM-A
I have a machine with a Fanuc OM-A control machine was running then droped out ...No alarms what so ever , machine will not come on now . I have no idea where to look .Input voltage is within spes.Control will not latch in. Where should I look ..What secquence should I follow to get machine to come on .Please help I know you wonderfull people have the knowledge to fix this . Thanks to all
Old 03-09-2010, 12:20 AM
WGoyer is on a distinguished road
Fanuc 0MA
Does the CRT stay on?
If yes, then it is most likely some external device with a problem (Axis drive or spindle drive etc.).
If No, then look for a short on the 24Volt system as that will drag the power supply down. If the 24 Volt system isn't shorted that indicates a power supply problem. The supply has small test points on the bottom. One of them is labeled A10, which is the 10 volt reference for the entire supply. This should read exactly 10 volts and should not drift.
Warren
www.uptimecorp.com
Old 03-09-2010, 07:08 AM
Thanks for the repley , the display will not come on will check the power supplies tonight thanks again .
MV-40B ATC dead steelhead1 Mori Mills 1 06-09-2009 12:30 PM
Need Help!- Fanuc 0 dead screen ... dead control? Noss Machine Fanuc 4 01-24-2009 09:03 AM
320 and Encoder dead together millmore Gecko Drives 6 12-12-2007 11:48 AM
CPU dead battery LT1TRUCK Computers and Networking 2 09-10-2007 06:47 AM
Uh-oh, I think he is dead kong DIY-CNC Router Table Machines 11 05-18-2004 06:20 AM
