HI ALL, I try to load a program into memory with my fanuc 6t-A controller following these steps: 1-set the lock key to write(unprotected memory) 2-set the mode selector key to EDIT 3-Press the READ key when I hit the read key An edit label is appear beside LSK label on CRT tube!! Can Any one help? thanks |
| As far as I know, this is normal, but I have only used the FANUC/GN6Mb. When the 'Edit' is flashing the contoller is ready for you to send the file from your PC. Eventually the NC file will apprear on the screen. Always check to make sure it got the file complete (there should be a percent sign at the beginning and end of the file). If you want to send a file too big for the controller's memory, you must set the dial to 'Tape' instead of 'Edit', then Press the green 'Start' key (The machine will then start running the program line-by-line as it recieves it). |
Also, the Fanuc control MUST see a valid line feed (LF) character to set the incoming tape code properly (ASCII or EIA). If it doesn't see this, the Label Skip will never disappear. Some programs such as Hyperterminal will not automatically turn a Carriage Return (CR) into a Line Feed (LF). They can be made to do it, but it takes a little work. Also, if you generate a CNC file with a Windows program such as Notepad, it will not contain LF characters. Fanuc CNC's MUST use LF characters, not CR to indicate the end of a block (EOB). Warren www.uptimecorp.com |
| I am using easyDnc software for sending and receiving data. Can any one send me a sample GCode tested before with fanuc6TA to tets it with my controller? As I said before when I try to send a file after I hit the read key Edit label appear beside LSK label and some times when I send my file it gives me alarm 075 other times when I enter LF "Ctrl+enter" in the begining of the file and afetr I send it Edit label disappear and nothing is change |
| Finally I loaded my program to fanuc memory ,But now appear a new problem that is after I load the program I set the mode selector key to Tape Memory to run the program but I found nothing !! I attched two pictures to my fanuc CRT first one when i set the mode selector to tap edit and the other to tape memory |
| Can not Edit Fanuc O-MC | minute man | Fanuc | 8 | 12-07-2009 03:47 PM |
| Need Help!- Cannot Edit Programs on Fanuc 31i-A5 controller | PeterTheWolf | Fanuc | 3 | 07-29-2009 03:44 PM |
| Fanuc Om Edit mode problem | Osmanselim | Fanuc | 0 | 03-06-2009 04:50 PM |
| Using Edit facility on Fanuc Oi-MC | cossiegaz | Fanuc | 7 | 01-12-2009 05:14 PM |
| Can't edit on OT fanuc!!! | steedspeed | General CNC (Mill and Lathe) Control Software (NC) | 17 | 06-04-2007 11:04 AM |
