Old 03-05-2010, 04:47 PM
YV600 is on a distinguished road
Parameter help on 11t control
I have recently aquired a TL40 with an 11t control. There are a few issues I am trying to resolve. First is setting tool geometry in "z". The procedure I believe is to touch off a pre made fixture, type Z0 and press measure. When I do this the controls tells me data out of range. Am I missing something? The next problem is setting the parameter to enable macro b. I turn on PWE and go to adjust a 9000 parameter the machine alarms with locked parameter. Is there something else I need to do?
Thanks in Advance
Old 03-05-2010, 06:19 PM
greenery_fr is on a distinguished road
hello
Thanks in Advance
http://www.cnczone.com/forums/showthread.php?t=94521
Need Help!- Parameter needed for Bridgeport Int. 412X. TNC 2500 control Eric Tay Bridgeport and Hardinge Mills 7 03-20-2012 05:17 PM
Newbie- Yasnac i80 control with flashing EBA!!!!/printing parameter list PaulRP General CNC (Mill and Lathe) Control Software (NC) 6 05-23-2009 03:04 AM
Need Help!- OM Control - RS232 - Parameter SHORT_JOHN Fanuc 1 04-15-2009 06:02 PM
Parameter to change for barrier control on a T2 lathe nervis1 Mazak, Mitsubishi, Mazatrol 3 08-28-2008 03:16 AM
Need help. Parameter for Bridgeport Int. 412X. Control TNC 2500 Eric Tay Bridgeport and Hardinge Mills 0 06-25-2008 09:29 PM
