Hi, I am trying to tap with my fanuc 10m it is on a victor v center 4 mill how do I see if it has rigid tapping? I am using g84 but when the tap goes down and threw the stock the spindal does not revers fast enough and it pulls the stock out the vise the z axis does not do this, it is the spindal I just need to know how to make the spindal stop and revers faster. Thank You |
| PM me your 9100 parameters and I will look at them and let you know if you have rigid tap. You also may have the wrong syntax. Can you post your code so we can look at it? Remember G84 is just a standard tap cycle. You will need a M29 along with G84 for a “rigid tap” cycle. Stevo |
| I assume you have a encoder on the final spindle shaft? Al.
| N1 G90 G80 G49 G40 G20 G17 N2 G00 G91 G28 Z0. N3 G91 G28 X0. Y0. N4 G30 Y0. N5 T1 N6 M06 N7 M03 S900 N8 G90 G54 X-2.5 Y0. N9 G43 H1 Z.5 M08 N10 G81 G98 X-2.5 Y0. Z-.1698 R.5 F1. N11 X-1.25 N12 X0. N13 X1.25 N14 X2.5 N15 G80 N16 Z.5 N17 M09 N18 M05 N19 G00 G91 G28 Z0. N20 G28 X0. Y0. N21 G30 Y0 N22 T2 N23 M06 N24 S874 M03 N25 G90 G54 X-2.5 Y0. N26 G43 H2 Z.5 M08 N27 G83 G98 X-2.5 Y0. Z-1.1604 R.5 Q.1005 F2.62 N28 X-1.25 N29 X0. N30 X1.25 N31 X2.5 N32 G80 N33 G00 Z.5 N34 M09 N35 M05 N36 G00 G91 G28 Z0. N37 G28 X0. Y0. N38 G30 Y0 N39 T3 N40 M06 N41 S595 M03 N42 G90 G54 X-2.5 Y0. N43 G43 H3 Z.5 M08 N44 G84 G98 X-2.5 Y0. Z-.7625 R.5 P0. F29.79 N45 X-1.25 N46 X0. N47 X1.25 N48 X2.5 N49 G80 N50 G00 Z.5 N51 M09 N52 M05 N53 G00 G91 G28 Z0. N54 G91 G28 X0. Y0. N55 G30 Y0. N56 M06 N57 T1 (END OF PROGRAM) N58 M30 % |
| Skippy, I am replying to your PM in the thread because it now sounds like you will have to start looking at what Al stated. Do you have an encoder on the spindle shaft? This will be Al's area of expertise. Stevo |
#11
| Skippyfix, Can I ask how you calculated the feedrate? It doesn't look right to me for a 1/4-20 tap. I have the same problem on a Mori I have with a 10M, it takes about 2-3 rev's to reverse - but I have to work around it. When I'm tapping blind holes I have to do some trial and error to get the tap to go as deep as I need it without bottoming out. I've never had a problem with the part getting pulled out of the vise though. John |
| GE Fanuc & FANUC proprietary posts | CNCadmin | Fanuc | 44 | 01-05-2012 08:54 AM |
| FANUC & GE FANUC Repairs | RRL | Product Announcements & Manufacturer News | 1 | 04-17-2011 11:50 AM |
| can fanuc ac digital servo amplifiers be run by a controller other than fanuc? | js412000 | Servo Motors and Drives | 5 | 03-09-2011 09:11 AM |
| Fanuc & GE Fanuc Repairs | RRL | Product Announcements & Manufacturer News | 0 | 10-01-2008 12:42 PM |
