Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 02-05-2010, 01:41 PM
Benchsmith is on a distinguished road
zmovement error!
I hope someone can help, We are running a old Fagor 8025. there was a -z movement in the program that grounded the head on the table. I cannot get it off the table, have tried to home it out and also just z+, also turned of the machine and back on, nothings working. Any advise would be great, thanks
Old 04-13-2010, 11:28 AM
Odin M Yggdrasi is on a distinguished road
I'd check for mechanical problems, if it hit with any amount of power behind it you may have damaged your ball screws and other vital machine areas.
Also check the fuses in the drive amplifiers.
Finally the last thing to try- depending on how hard it hit, it may have overtravelled the Z axis. The machine will simply not move if it is outside the soft position limits, so you might need to move the Z negative soft position limit to well below the point of impact just so that the machine can raise itself clear again.
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Need Help!- Matsuura Mc500v seq error/magazine error mc500v General Metal Working Machines 10 01-08-2010 01:35 PM
Need Help!- Error 414 Z axis error detect- servo alarm andywids Fanuc 0 07-09-2009 10:33 AM
Need Help!- Error 414 Z-axis error detect servo alarm andywids General Metal Working Machines 1 07-09-2009 09:56 AM
