Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Fagor Automation
Fagor Automation Discuss Fagor Automation products here.
Old 02-03-2010, 03:02 PM
Geo@az is on a distinguished road
FAGOR 8020-GP CNC PARAMETERS
We have acquired a used FAGOR 8020 8" Monochrome Monitor.
We installed it and it worked correctly. The trouble now is after reassembling the CNC unit and powering everything up the machine will not operate and the screen displays errors, moreover, the texts on the monitor appear in Spanish. I assume that since I had the CNC unit without power for months all the machine parameters reset to the default settings.
Our CNC is a FAGOR 8020-GP witch controls an automated punching machine. It handles two axis only (X and Y). We have the start up manual, however there are 204 different MACHINE PARAMETERS to be entered, not mentioning the DECODED M FUNCTIONS and the LEADSCREW ERROR COMPENSATION.
Who can help me with this? Perhaps there are standard parameter settings for this particular CNC operation.
Is anybody familiar with this problem?
Puedo leer Espanol tambien.
Old 02-11-2010, 03:57 PM
[QUOTE=Geo@az;728133]We have acquired a used FAGOR 8020 8" Monochrome Monitor.
We installed it and it worked correctly. The problem now is after reassembling the CNC unit and powering everything up the machine will not operate and the screen displays errors. I assume that since I had the CNC unit without power for months all the machine parameters reset to the default settings, in other words I think the parameters were lost.
Can someone assist me with this issue? or, where can I get the right parameters again for this type of machine?
Our CNC is a FAGOR 8020-GP witch controls an automated punching machine. It handles two axis only.
Old 02-15-2010, 09:28 AM
alphonso is on a distinguished road
First thing to do: is the battery good? It is found under the little black box on the upper left side of the back side of the control, next to the heat sink. There are several wires (red, black, blue?) that go thru the plate to the inside of the control. Remove the screws that hold the back cover and swing it out. The wires from the battery go to a plug on the cover. Then wires from this plug go to another plug on the control boards. Make sure that both of these plugs are plugged in.
After verifying and/or replacing the batteries, start control,
go to editor page, press display mode, then lock/unlock. Type in PKJIN and press enter.
Next, go to parameter page, type in p204 and press Recall button. This should bring up the language parameter. Change it to the language you want and press Enter button.
Now type in P0 and press Recall. Enter parameters, it should take less than an hour because there are lots of parameters you won't need. Anything you don't use enter a zero or no.
Personal preference: P121.5= 1. This activates the DNC link on start up. If you are going to upload/download programs this has to be active.
I assume you have the start up and installation parameter manual. If not you need to get it from Fagor.
Old 05-10-2010, 01:52 AM
DHO.nl is on a distinguished road
We have a simulair machine a 8020 PG with a extra PLC64 unit. I recently checked the battery and by doing this all parameters were reset. We had a list with all the parameters so when so entering the parameters was no problem. When you still in need of it let me know, I can send it to you.
But the problem we have is that every time when starting we get:
Error 094: Parity T, G53-G59
We can not do a reference ride (G21 N99), or can edit or enter a program.
Also I can not send progr. files by DNC mode while sending and receiving tables is no problem except the fact that when send/rec. the tool table does not give the right format.
Any help or suggestion will be appreciated.
Old 01-26-2012, 10:27 AM
viorel is on a distinguished road
how I could study a manual for FAGOR_8020-GT?
Thank
Old 02-15-2012, 07:12 PM
CNCTech25 is on a distinguished road
You have a checksum error in the tool table.
I'm not familiar with 8020 controls, but the 8025 is similar and I do know about those so try this out:
Pull up the tool table. look to see if the screen says checksum towards the bottom. If it does you need to type in a code to clear the checksum. for turning controls type in KAI, for milling/gp type in KJI. then press enter.
Also when on the tool table screen, press G and G53-59 will come up, check for checksum towards bottom as well and if its there type in the code.
Again, thats how it is for a 8025, hopefully that will work for the 8020 as well.
Yet Another 8020 CNC Build jsantos Open Source CNC Machine Designs 203 04-29-2012 04:14 PM
New Machine Build- 8020 build 3x5 sieg01 CNC Wood Router Project Log 30 03-17-2009 04:08 PM
Newbie- Help w/8020 Jcyr1 DIY-CNC Router Table Machines 3 09-03-2008 02:04 PM
Need Help!- Supermax YCM-30 Fagor 8025m Parameters toolguy Machine Problems, Solutions , Wireless DNC, serial port 0 03-27-2008 12:42 PM
Fagor 8030 parameters jerryhm General CNC (Mill and Lathe) Control Software (NC) 0 11-30-2007 02:22 PM
